![]() | Home > Faults & Fixes > Engine System Fault |
PHinett Member Since: 21 May 2014 Location: Birmingham Posts: 63 ![]() ![]() ![]() |
I had an engine system fault a few weeks ago, it was intermittent probably once every 3/4 days. Had someone take a look with a generic reader which showed no error codes, but looking under the bonnet he noticed an air leak from the EGR valve to the intake minifold?
Are they easy enough to check while still attached or do they need to be removed? 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps |
Sometimes a split can be hard to see without removing the hoses.
cjohng Member Since: 26 May 2019 Location: newcastle Posts: 3 ![]() ![]() ![]() |
aye checked my intercooler hoses and look ok not the easy fix for me then |
i'll get the codes read today |
