Home > Technical > Cluncking
alpaca
United States 2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Cluncking
I am getting occasional clunking from rear on when driving slow over cats eyes etc. I took a look underneath - the rear mufflers are attached with rubber mounts - I can move the cans enough by hand to clunck against the heat shield bolts . Also the damping weights near the rear bumper will hit the mounting bolts if I swing them back far enough - this is the only things that I can see are obviously loose (I changed swaybar bushes and links a month ago that fixed different knocking sound). Should the exhaust and damping weights be able to knock against things back there ?
Post #461720 Mon May 11 2015 4:10am
Camelrock
Did you check for play in the ball joints on the ARB linkes. Sway bar bushes ? Do you mean the ARB 'D' bushes. Rock the car see if you can hear any knocking. Check the front D bushes etc. check for worn sus bushes.. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #461728 Mon May 11 2015 10:15am
frostmotorsport
New Zealand 2006 Range Rover Sport Supercharged Rimini Red
Our 05 RRS has some aftermarket mufflers fitted (they were there when we bought it) and the damping weights do indeed knock against the mufflers over various bumps and bits of road. Every home should have one!
'06 RRS SC Rimini Red
'04 Audi S4 Avant
Escort Mk II Sport
Post #461738 Mon May 11 2015 1:15pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Had exactly the same- drove me mad. Took it to my local exhaust place, they applied a little heat and bent one side of the exhaust away from the balance weight things. All good now
Post #461746 Mon May 11 2015 3:32pm
alpaca
Yes - I replaced the arb (swaybar) d bushes and drop links - so i don't think noise is coming from there (previous noise from that was different). All I noticed that was loose was exhaust - but didn't see any obvious bolts missing - it just rocks on its rubber mounts.
I guess it could be control arm bushing - but wouldn't that knock more on breaking or acceleration ? Mine is kocking when driving in straight line at low speed over a small bump like cats eye
Post #461818 Wed May 13 2015 6:04am
Camelrock
If you drive forward slowly then tap the brakes do you get the knock, if so then it's prob the front sus arm lower rear bushes, most then change the complete bottom arm but I normally change just the bush. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #461822 Wed May 13 2015 10:23am
alpaca
No Cluncking on braking .. Just rattle type sound or clunck from rear - worst at low speed when driving over uneven pavement. I think I'm going to remove the wheels and check the torque on all the arb/sway bar bolts again .... Seems like rear control arms are unlikely source for this ?
Post #461977 Fri May 15 2015 2:07am
alpaca
Checked underneath this weekend - yes the right side muffler is close to the counter balance weight and you can swing it on its rubber mount so it clunks against there - but swaybar link bolts were also a bit loose after last off road adventure - so I tightened those up - must loctite them next time - and test drove - no more clunck - so I think that was it ...hard to get a torque wrench in there so just used 18mm ratcheting wrench - stock is 17mm I think - on upper bolt that connects link to swaybar (arb)
Post #462212 Mon May 18 2015 4:26pm
