Home > In Car Electronics > Sat Nav Fault. 2005 RR Sport SE
Mighty Fly
United Kingdom 2005 Range Rover Sport TDV6 SE Java Black
Hi, the Sat Nav seems to have developed a fault. It recognises the postcode of the detination, but seems to be stuck on a particular location, or does not change to where I am going.
Any ideas on the fix for this.
Post #461589 Fri May 08 2015 10:29pm
PHinett
Have you got a waypoint setup...I have done this befor it remembers the waypoint until you reach it And will always point you there first before your destination. 57 Reg TDV8 - Java Black - Privacy Glass - Side Steps Smile
Post #461590 Fri May 08 2015 10:36pm
Mighty Fly
Yes, ive tried to delete it but to no avail. Not for any other reason other than i thought it may do the trick. Is there something else i may need to do.?
thanks for your help.
Post #461593 Sat May 09 2015 1:14am
Mighty Fly
I've now figured it out to a degree, but still having difficulty pinpointing the exact location, and direction of the arrows in respect of which way the car is pointing.
Does the map need to be zoomed right in to do this successfully?
Thanks in advance.
Post #461640 Sat May 09 2015 6:04pm
Mighty Fly
Eventually managed to sort the problem out and now all is fine.
After setting your location, the directional arrow need to be pointing facing the direction of the wheels I believe.
Post #462098 Sun May 17 2015 11:08am
