Home > Maintenance & Modifications > Removing The External Lower Door Trim |
darrenmcneill Member Since: 05 Oct 2014 Location: Whitworth Posts: 442 |
Is the lower external door trim removed by pulling off (in the usual RRS fashion), or are there any screws holding it on? Also, does anyone have the item number for the clips that will likely break when the trim is removed?
Sun May 03 2015 7:34pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
If I remember right I think the Front Door trims just pull off and there are two different types of clips used on the door some are Black and the others Yellow/White, the Rear Trims have a Screw at the Back Edge of the door as well, they use only the Yellow/White clips.
Sun May 03 2015 8:32pm |
Cheers!! 2006 HSE for Sale - £7,499 (Manchester)
Mon May 04 2015 7:57pm |
