Home > General > Finally found a way to replace parking sensor - easy fix!
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I had asked and tired may ways to get the front side parking sensor out and they all did not work for me. But today when replacing my headlamps I seen what a big gap it makes when you take off the grill and lights, so was simple to actually see the unit and flick off the clips. Was so happy!
But now it has fixed it does not say front parking sensor fault on the dash no more but does a long tone as it used to. I still cant see the senors working. I read that you need them reset, how is that done? Can I disconnect the battery to do this?
Think I seen that a while back - but I'm hoping there is an easy way.
Thought it was worth sharing this tip as I had tried all the other ways like removing the inner tyre screws and popping off the side of the the bumper but it was too tight.
I'd appreciate any help to reset the unit now so I can test it at last!
Post #461069 Sun May 03 2015 3:14pm
