Home > Detailing & Car Cleaning > Wheel Cleaning
Mark41
Wheel Cleaning
hi there,
recently bought RRS TDV8 on a 57 plate. Love the car!
I was wondering what the best wheel cleaning product is? Does anyone have any recommendations please? Have got Wonder Wheels that was used on last car but not sure if this will damage the RRS alloys
Thanks
Post #460946 Fri May 01 2015 8:51pm
SPX
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
I use Auto Smart alloy wheel cleaner, never failed to budge the worse grime/brake dust.
Post #460947 Fri May 01 2015 9:18pm
Mark41
thanks SPX.
Does anyone know if Wonder Wheels will damage the RRS alloys?
Post #460949 Fri May 01 2015 10:34pm
jeffhunt
Might be a coincidence, but I noticed staining/streaks on mine after using wonder wheels?
Used it on my XF previous to the RRS with no problems... So it might just be me putting 2+2 together and making 5
I use Auto Glym wheel cleaner now (came with the car life-shine pack) no acid, seems to work good.
Post #460958 Sat May 02 2015 7:32am
kbklr
agree acid free, fresh warm water and often
Post #461426 Thu May 07 2015 6:30pm
wonder wheels should not damage the alloys if they are intact and free of chips, as long as you follow the instructions and do not let it dwell for too long
if you have baked on brake dust, try something like Iron X Gel, if its bad Iron X paste and ones purple jet off, then on to a clean with (wonder wheels) or something acid free
main thing, is don't scrub as this will marr the finish, soft wheel brushes, regularly rinsed in a bucket, as brake dust is very abrasive and thew biggest thing to do once clean is seal them with a good high temp wheel wax, or even better a nano sealant
Post #461453 Thu May 07 2015 7:51pm
Mark41
thanks for those replies folks!
Post #461476 Thu May 07 2015 8:44pm
Barbara
Spain
brilliant, they seem to be new
Post #461760 Mon May 11 2015 5:48pm
JSR2014
England 2013 Range Rover Sport Supercharged Santorini Black
I swear by Bilt Hamber, won all the tests a year or so ago - spray on, wait for it to go purple and power hose off. Use a wheel brush for any stubborn areas. It even brought my calipers up a treat...The best part is that its PH Neutral so its safe for all types of wheel as well
http://www.autoexpress.co.uk/accessories-t...auto-wheel
From memory Opie Oils sell it - http://www.rrsport.co.uk/forum/member-oilman.html 2014.5 Mariana Black 5.0 Supercharged V8 Autobiography
Post #461795 Tue May 12 2015 7:41am
Violetpiano
Mark,
I have always used Meguire's wheel cleaner. Been using it for over 10 years. Spray it on and leave it for a couple of minutes and you only have to gently agitate any stuck on brake dust with a non corrosive brush and just rinse it all off. Absolutely no smear marks or stains and I live in a hard water area.
Jas Current RRS: MY18 SVR
Previous RRS: MY15 RRS 5.0L Autobiography
Post #461807 Tue May 12 2015 7:53pm
Bungleaio
2005 Range Rover Sport Supercharged Buckingham Blue
Once you've got them clean I highly recommend this http://gtechniq.com/products/auto/perfect/...eel-armour
It's not cheap but it means you can just rinse the dust off your wheels for quite a while.
The wheels do need to be clean though so it's worth taking them off and doing a proper job.
Post #461810 Tue May 12 2015 8:15pm
daniel
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
I've used many of the products since I've been interested in having a clean car but you can't beat wonder wheels for the value
http://www.halfords.com/motoring-travel/cl...aner-500ml
it says no brushing required i use a small soft paint brush for the corners but its currently 3 for 2 so an excuse to buy some more stuff Thumbs Up
Post #461874 Wed May 13 2015 8:38pm
Brian
Scotland 2013 Range Rover Sport SDV6 HSE Stornoway Grey
I got some of the Wonder Wheels Hot Wheels for use on exactly the same wheels you have and it worked a treat, stripped all the dirt and grime off and left them very clean. Did a god job on the winter's baked on brake dust too but I also used a wheel brush to agitate it. Got it on the three for two offer at Halfords, it was the free product, but if you're only buying it on it's own watch the price.
Halfords have 500ml for �9.99 but if you've a Wilko's (or Wilkinson's) nearby they have 750ml for �6.00. I'm sure I've also seen it at this price in one of the supermarkets but can't remember which one. Cheers
Brian
Owned: '13 HSE Black Edition 3.0 SDV6 Stornoway Grey
Gone: '57 HSE 3.6 TDV8, Zermatt Silver
Gone: '02 Discovery 2 TD5
Post #461976 Thu May 14 2015 11:46pm
Ian.H
Billberry or Chemical Guys for the cleaner, if you want a wax rather than ceramic coating, either Poorboys Wheel Sealant of FinishKare 1000p wax works wonders.
Cheers..
Ian
Post #461990 Fri May 15 2015 10:04am
Tyrefitter
I've just waxed my wheels with poorboys wax,I've given them 3 coats as recommended it took me 5-6 hours to do all 4 wheels then I clean with Bilberry as its acid free so no damage to the alloys.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #470057 Mon Aug 10 2015 8:20pm
