Home > Maintenance & Modifications > Brake fluid change
Morgi27
Brake fluid change
Hi guys
Going o renew my brake fluid and pads all round soon and just wondered is there anything
I need to know has to bleeding brakes on the rrs 2005?
I use the ezibleed system which really does a great job,but just want to be sure not going to upset anything in the car
If I do a bog standard bleed etc
Post #460848 Thu Apr 30 2015 2:01pm
Bodsy
Site Sponsor
that's fine, just make sure the reservoir doesnt go empty (as all other cars really)
I think the order is Rear left, front left front right rear right. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #460854 Thu Apr 30 2015 2:14pm
Morgi27
Cheers!
I was always told to start with bleeding the wheel the longest away from the brake reservoir and work way forward to the nearest last
Dunno if it really matters?
Also if I change the discs also on the rear and wind down the handbrake mechanism through the inpection hole on the disc
How many times do I turn it back to release it? Some say 8 some say 5? And I'm guessin handbrake is off before I wind it down to tighten the disc first before releasing
Post #460871 Thu Apr 30 2015 5:10pm
Bodsy
Site Sponsor
I'm sure that would be fine too.
As for adjusting the brakes, have a read of my brake bible.... (See link in my sig below) Thumbs Up Bodsys Brake Bible
See it HERE
Post #460874 Thu Apr 30 2015 5:21pm
Morgi27
Yes I just read it! Very very good! Cleared everything up I needed to know
Thanks a lot matey! Thumbs Up
Post #460880 Thu Apr 30 2015 5:45pm
