Home > In Car Electronics > 2005 auxiliary input
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Tried to connect my Sony experia via this with a male to male audio lead to play some tunes, set the unit to aux and all I got was a lot of noise but no music.
Can anyone advise or help
Post #460808 Thu Apr 30 2015 7:03am
simbad111
what i tend to find is that connect the phone select aux then pull out the jack plug to the phone and reconnect, but make sure you push in fully,
Post #460814 Thu Apr 30 2015 9:12am
Bodsy
Site Sponsor
some of the jacks have a plastic shroud that just stops the pins from going in far enough to make the proper connection. I've had to trim some of the plastic off sometimes to get the right connection. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #460820 Thu Apr 30 2015 9:58am
monty19
Bought a new lead and all is working, thanks for the advice people Thumbs Up
Post #460893 Fri May 01 2015 6:42am
