Home > General > Rear roller blind
Morepower
England 2007 Range Rover Sport TDV8 HSE Rimini Red
Rear roller blind
Has anyone tried to re tension the rear load cover? Mine had the screw come out and I have put it back together but it's now really loose and doesn't recoil back properly, looks terrible and rattles and swings about, any help appreciated.
Cheers guys
Graham
Post #460539 Sun Apr 26 2015 8:56pm
Morepower
Anyone😩😩😱😱
Post #460617 Mon Apr 27 2015 9:25pm
Paddi
Sometimes no-one knows the answer which is probably why there have been no other replies.
There have been reports of 'roller blind' broken springs or springs losing their tension. If you are the practical type maybe try dismantling to find the problem. Alternatively try taking it to to a roller blind specialist or a coach trimming specialist and have them look at it? 2008 MY Java Black TDV8 HSE
Post #460679 Tue Apr 28 2015 2:41pm
Russben
I retensioned mine when a screw came loose. I just wound the blind backwards until the spring resistance felt tight enough & then pushed the end cap back on & tightened the screw back up again. It wasn't too difficult. I'm in the shed, I'll be back in the real world in a minute.
Gone- 2010 TDV6; Hello 2017 SDV6.
Post #460746 Wed Apr 29 2015 12:48pm
mr_spaceuk
Mine has also gone loose, and so I'm going to give this ago too.
Post #460788 Wed Apr 29 2015 8:40pm
AlanEricThompson
England 2010 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
My blind tension is ok, but the end cap that is spring loaded is loose. This causes the whole thing to rattle as it is not fitting tight enough, it drives me MAD when I have a squeak.
Any suggestions?
Alan 3.0 HSE RRS Stornaway (current)
Evoque Prestige Lux (gone)
3.0 a Disco 4 (gone)
Post #460834 Thu Apr 30 2015 12:54pm
Russben
Tighten the screw up again & check the boot side panel trims are secure. Aparently the plastic retaining clips can break in the side panels if a dog guard has been fitted and that can cause a rattle/squeak (the dog guard pushes the trim panels outwards & breaks the clips).
Mine rattles & squeaks and replacing the clips is a job I've still to do. I'm in the shed, I'll be back in the real world in a minute.
Post #461081 Sun May 03 2015 9:31pm
bossman115
I have stripped my blind right down and re-tensioned the springs but I am stuck on how to hold the tension whilst trying to locate the stupid grub screw on the end and line it up to the centre bar. After 3 hours and loads of blue air I give up!
Post #530147 Tue Jul 11 2017 8:42pm
