Home > Maintenance & Modifications > Power steering leak |
MJ87 Member Since: 04 Jan 2015 Location: South Yorkshire Posts: 63 |
Could somebody please identify this leak? Power steering reservoir has dropped about an inch below minimum over the last month.
Mon Apr 20 2015 8:53pm |
Cheers RRSTDV8.
Tue Apr 21 2015 12:27am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Not sure the valve is a serviceable item. The transducer is but that's an electronic item on the rack that controls the valve.
Tue Apr 21 2015 7:19am |
Thanks,
Tue Apr 21 2015 7:47am |
If it's leaking then I suppose it could cause the notchy steering because the moment it leaks will result in less power steering effect. 2012 SDV6 - it's missing a couple of cylinders
Tue Apr 21 2015 7:59am |
I managed to get it looked at by a garage this afternoon.... they reckon the UJ is causing the notchy and stiff steering and needs replacing which doesn't surprise me.
Tue Apr 21 2015 4:27pm |
Garage has got back to me saying they have been told that a full steering rack is required for a total cost of £1500
Wed Apr 22 2015 4:02pm |
My steering rack was replaced under warranty and the price noted on the paperwork is £1173. That is excl VAT but I assume includes labour. There was a surcharge on the part - presumably it's an exchangeable unit. That was at a main dealer.
Wed Apr 22 2015 4:50pm |
Bit of good news...The leak has been fixed and all it cost was £70! New o rings to the pipes that enter the servo valve and refilled the power steering fluid. Also cleaned and greased the steering UJ - he didn't think the UJ needed replacing as he thought it was in good condition.
Thu Apr 23 2015 5:46pm |
Excellent news. I wasn't sure the rack was serviceable but it obviously is in part. A great outcome. 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 23 2015 7:19pm |
Cheers for your input on the subject RRSTDV8
Thu Apr 23 2015 7:34pm |
I had a new power steering pump fitted under warranty a few weeks ago. I think it's a good couple of hours' work. 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 23 2015 8:41pm |
