Home > Technical > "Dead" key battery (2005/2008 type one)
verydisco
Hi
On my friend's 2.7L RRS, one of his key is completly dead as it has never been used.
Would simply putting it in the lock and clicking it one position 1 recharge it or is it dead for good?
Anyone knows if key batteries charge as soon as position 1 is reached or if the engine has to be running ?
tx
Post #460214 Thu Apr 23 2015 10:14am
Lost for Words
Tape it to the other key and go for a long drive. Wink Visiting from DISCO3.CO.UK
Post #460224 Thu Apr 23 2015 11:35am
verydisco
I understand you mean with the dead one in the lock and the working one taped to it to ok the electronics, right?
Post #460226 Thu Apr 23 2015 11:37am
Lost for Words
No, I meant the other way round. Thumbs Up Visiting from DISCO3.CO.UK
Post #460227 Thu Apr 23 2015 11:38am
verydisco
Well how is the dead one going to recharge if it is not connected via the blade?
unless they do not charge via the blade but by induction???
Post #460228 Thu Apr 23 2015 11:41am
Lost for Words
They do indeed use the hall effect to charge. Thumbs Up Visiting from DISCO3.CO.UK
Post #460230 Thu Apr 23 2015 11:43am
verydisco
Thanks for the input Wink Hope it helps others too
Post #460231 Thu Apr 23 2015 11:47am
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
If you have an electric toothbrush.. put the toothbrush on charge and rest the key against it / the charging base.. I've found this worked for my old BMW E46 key in the past for a similar reason.
Cheers..
Ian
Post #460232 Thu Apr 23 2015 11:48am
