Home > In Car Electronics > Different Dash Cams |
hse-lee Member Since: 17 Jan 2015 Location: london Posts: 77 |
hmmm interesting i really wanna get one of these fitted asap due to all the planks who seem to have a car their intent on driving badly, question do you have to manually power yours/switch on every time u get in the car id like to just get in and go with it starting up with the car automatically
Sat Mar 21 2015 4:09pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Yes that is the same as mine. I ran the power cable,from camera near rear veiw mirror across sunvizor inside door rubber trim, under dash panel below steering wheel,pushed in gap between dash and centre consul, then plugged into cigar lighter. It starts working as soon as you open door,and carries on working for a set time after switching off. It shows a blue LED when it is recording. Mine was £39 from IJT Inks. But as yours said make an offer. It also records over the first recording when it runs out of space. But with a 32GB you should get around 100 hours itisme |
Sat Mar 21 2015 4:36pm |
oh wow that sounds great auto power on power off £40 could you ask for anymore i plan on cutting the cable and hardwiring it to cigarette lighter that way it won't be seen at all my good man you have just saved me £140+ |
Sat Mar 21 2015 4:42pm |
did you opt for the gps unit too ?? would you say this is necessary |
Sat Mar 21 2015 4:47pm |
I have seen the GPS unit on Ebay for around £27. I suppose its a good extra if you dont know exactly where you are if you have an accident. As this records the roads you are on, time and speed. but you cant see this until plugged into a PC itisme |
Mon Mar 23 2015 8:15am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
There are some reviews here
Mon Mar 23 2015 8:48am |
Another camera to consider is the one variously referred to as the Mini 0801 or Black Bullet or 'E- Prance. There are later evolutions known as Mini 0803 and I think even now 0805.
Tue Mar 24 2015 6:13pm |
zaphod Member Since: 16 Jan 2015 Location: Liverpool Posts: 290 |
You mean this? http://www.registratorviewer.com/index_en.html?
Wed Mar 25 2015 9:26am |
Just had a quick look at your camera specifications and it looks like it records in the .mov file format which can be read by registrator viewer so why not give it a go? All you have to do is download the software and then install it on the root directory of the SD card you are using. Put the SD card in your computer, browse to the card and start the software from there and it should automatically find your files and load them.
Wed Mar 25 2015 9:14pm |
Thanks for that Paddi... took me a couple of weeks to get around to trying this out but I did as you said and put it on my memory card and it worked, even the bit where it shows your route on google maps
Mon Apr 20 2015 11:27am |
Mon Apr 20 2015 11:39am |
