Home > Off Roading & Green Laning > Mt's on a RRS 3.6l TDV8 2008?
Mounty
Switzerland 2008 Range Rover Sport TDV8 HSE Baltic Blue
Hi everybody
Do fit 19'' Mts and wheels on RRS 3.6l TDV8 2008 with Brembobrakes?
Thanks for your answer Daniel
Now: RSS 2008 3,6l HSE
Past: 2.7l D3 HSE, D3 4.4l HSE, FFRR 2004 4,4l
Post #459362 Thu Apr 16 2015 8:50am
You can fit certain 19in wheels over the Brembo brakes. There are not many choices of MT that fit 19in wheels, sadly. 2012 SDV6 - it's missing a couple of cylinders
Post #459383 Thu Apr 16 2015 1:15pm
Disco_Mikey
Goodyear Duratrac
Cooper Zeon LTZ
You may have to go to a 55 profile though...
Post #459386 Thu Apr 16 2015 1:25pm
Neither of those is really a MT though. The LTZ is definitely an AT and I think the Duratrac is more "extreme AT" than MT. Both in /55 profile as you say.
Atturo make the Trail Blade M/T in 255/55/19 but I don't know if they're easy to get hold of. It is a "proper" MT tyre though:
In 20 in rim sizes, they do the Trail Blade XT (in 275/45/20) which looks like a good compromise off road tyre:
Post #459406 Thu Apr 16 2015 6:06pm
Mounty
Do this fit? Come off a Disco3 inkl. Mts. Daniel
Post #459417 Thu Apr 16 2015 7:46pm
Mounty
Tailblade looks awesome Thumbs Up Daniel
Post #459419 Thu Apr 16 2015 7:50pm
The front left wheel will fit - I have those on my TDV8. I think the others will too. 2012 SDV6 - it's missing a couple of cylinders
Post #459421 Thu Apr 16 2015 8:00pm
Lsv
Netherlands
My solution. Compomotive pd1880
They fit on my rrs with Brembo pack, although even 18"
Phonic blocks have to be turnen 189 degrees. Fairly easy job with a standard Allen key.
In 18" there are a lot more options in tires. I fitted general all terrain.
Post #488177 Fri Feb 19 2016 10:23pm
Tim in Scotland
IIRC the Compomotive PD1880 wheels were specially made for Bowler for the Bowler Nemesis RRS-a-like that was nearly a tonne lighter and an offroad racer. The forum looked into doing a Group Buy of them but even when we got 20 sets of 4(that was the minimum order number!) they were hugely expensive and we didn't go ahead. There were also concerns IIRC that their load rating was not high enough for the weight of the RRS1 as they were meant for a lightweight GRP/Carbon Fibre bodied Nemisis not a steal bodied Land Rover RRS! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #488284 Sat Feb 20 2016 7:22pm
Buckster
One of these awesome creations Tim Thumbs Up
 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #488286 Sat Feb 20 2016 7:39pm
Lsv
Netherlands
I must damit I have a little bit of an advantadge.
I have my own company in specialty vehicle lighting (for emergency services and rallysport) and a few connections in the rally world.
We supply a number of Bowler teams with our lights and hence I was able to contact Compomotive.
I can now order them at a single set each time, rather than an enormous badge of 20 sets at a time.
Did the same thing for a few Lotus friends, they also run their trackday tires on Compomotive.
Just curious, what was the quotation to the forum members?
Your weight calculations are correct. The rrs is about 2650kgs empty, the Nemesis is between 1800-1900 kgs, dependant on the version. Beautiful vehicle though!
Best regards Ruud-Peter
Post #488296 Sat Feb 20 2016 8:22pm
disco4x4au
Australia 2013 Range Rover Sport SDV6 SE Santorini Black
We designed the PD1881 Compomotive specifically for the D4 / RRS - it's load rated to 980kg.
Cheers,
Gordon 2015 RRS SDV6 SE, Santorini Black, GOE 2-way HS rods, Traxide dual battery, 275/55R20 Nitto TerraGraplers
2015 Discovery 4 SDV6 HSE - GOE 3-way HS rods, GOE underbody plates and sliders, 275/65R18 Courgia MT
Post #488734 Wed Feb 24 2016 2:18am
