Home > General > SOLAR BATTERY charger - do they work?
Page 1 of 3 123>
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
I have a 2009 Sport. The battery is 12 months old. I am having problems with parking up for a few weeks and finding the battery hasn't much if any live. I have been looking at buying an...... AA Car Essentials Solar-Powered Car Battery Charger....has anyone any experience as to if they are any good. Andrew Kennedy
Post #459039 Mon Apr 13 2015 1:18pm
Tim in Scotland
Andrew I used to use a Maplin £10 one with a blocking diode to prevent the solar panel from drawing current at night on my 2007 3.6TDv8 RRS and 2010 FFRR. The panel would not work on either of my Evoques as none of the sockets stayed live with the ignition off although on my 1st Evoque LR did a Battery management software upgrade that re-instated the boot socket by accident but the next software upgrade removed it again! I was leaving cars for 3-4 months at a time with the solar trickle charger plugged into the front socket. The solar panel was left on the centre cubby box lid or the dash and worked fine - in my FFRR I use to leave it on the centre cubby box under the sunshine roof. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #459042 Mon Apr 13 2015 1:49pm
andrew kennedy
Thanks for that. Very helpful!! The solar charger I am considering plugs into the plug socket that is situated in one of the foot wells, the plug used to check out the computer. What would you think? A suitable socket to use?!? Andrew Kennedy
Post #459049 Mon Apr 13 2015 3:21pm
ilard
I would be interested in a complete solution for this (RRS 2011MY), but the key issue as I see it is not having a lighter socket that is live with the ignition off.
Is anyone offering / selling an end to end solution out there? L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #459064 Mon Apr 13 2015 6:05pm
ilard
Post #459065 Mon Apr 13 2015 6:05pm
fkarim
^^^ In my MY13 I have removed a relay from the fuse box behind glove compartment. Jumped it using a fused wire (don't know if adding the fuse was necessary but I didn't see any harm in doing that). Now the socket behind the centre console and the one in the boot are permanently live and I use a CTEK charger via the boot socket. Can't be too different (if at all) in MY11.
There are pictures and details here and on disco3 if you search. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #459067 Mon Apr 13 2015 6:22pm
flydive
You could connect the panel plug to the towing electrics fuses in the boot. '08 RRS TDV8
Post #459072 Mon Apr 13 2015 6:44pm
Lost for Words
Easy enough to wire up a suitable feed and, as above, the towing electrics could be made use of when fitted. Thumbs Up Visiting from DISCO3.CO.UK
Post #459074 Mon Apr 13 2015 6:56pm
andrew kennedy
I understand that connecting the solar panel directly into the EOBD connecter is the way to go. Andrew Kennedy
Post #459117 Tue Apr 14 2015 8:46am
viper
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Bali Blue
Used one on garden tractor for a couple of years been great never had any starting problems each spring Thumbs Up 2016 bmw x5 40d m-sport space grey
2015 bmw 335i m-sport touring mineral grey/coral interior looking to change again .
Gone HSE SDV6 Dynamic indus silver, santorini contrast roof,panoramic roof,red brakes,privacy,climate front seats,tow bar great car enjoyed it ����
Gone my10 3.0 tdv6 Bali blue/ivory 5 years 24k no problems great car will be missed
Post #459142 Tue Apr 14 2015 12:05pm
myfirstrrs
I haven't had a particular problem with my battery but as my car often goes a week or more without being used I invested in a solar powered maintenance charger form Maplin's, £20. I connected it last Sunday after measuring that the battery had 12.29 volts, left the car all week and now it has 11.86 volts. I'm gutted, but can anyone please help me to understand why a maintenance charger can cause the battery to lose charge?
Post #464464 Sat Jun 13 2015 4:51pm
myfirstrrs
Anyone? Before I head off to Maplin's for a refund.
Post #464504 Sun Jun 14 2015 8:09am
SimonR
You need a charger with some battery management 'intellegence'. Even a blocking Diode is better than nothing. Without it, the panel will draw current when the sun is not shining.
It's possible yours has this and it's faulty - or that where it's placed it just isn't producing enough power to keep the battery charged.
I've found solar panels barely work inside my truck - the glass / tinting screen out all the UV (I suspect). Open the sun-roof and it comes to life!
Before you return it, try leaving it outside (middle of roof) with the cable jammed in the door & see if that helps?
Si
Post #464673 Mon Jun 15 2015 6:20pm
Bodsy
Site Sponsor
Was it this one....?
http://www.maplin.co.uk/p/solar-powered-12...rger-l58bf
I would say you need something bigger than 1.5w
Additionally, how did you connect it? If on the Cigarette socket, it isnt live when Ign is off unless you have bypassed the relay. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #464682 Mon Jun 15 2015 6:49pm
myfirstrrs
It was that one bodsy, but I have now swapped it for this (2.4W instead of 1.5W), just not had a chance to try it yet:
http://www.maplin.co.uk/p/solar-powered-12...rger-n59fu
I wondered about the permanent live in the lighter socket and even though I haven't changed anything, when I use a multi-meter with the ignition off I can read the voltage. In my simplistic world that means that it is permanently live. Is that correct?
Thanks for your input also SimonR, it does have a diode to prevent reverse charging.
Post #464687 Mon Jun 15 2015 7:15pm
Page 1 of 3 123>
