Home > Technical > Cruise control Error with Fault Code
zaphod
OK, my car drives perfectly, I just have intermittent issues with the cruise control. Sad
Sometimes I cannot turn it on at all, other times once it is on I cannot adjust the speed up or down. Sometimes I cannot turn it off and have to press the brake to disengage it. The rest of the time it works perfectly!!! I should mention that at no time is any error displayed on the screen when I experience problems.
I got the fault code using my IIDTool:
Engine - P0579-00( 68 ) Speed Control multi-function Input A-Circuit range/performance...
No idea what that means - hoping someone can point me in the right direction! Smile
Post #458839 Sat Apr 11 2015 6:14pm
Disco_Mikey
http://www.rrsport.co.uk/forum/topic39951.html
Post #458840 Sat Apr 11 2015 6:23pm
zaphod
Thanks - I did see that post but it had a different error code which threw me off the trail... so basically it's the same fault and I should try replacing the loom in the steering wheel yes?
Post #458842 Sat Apr 11 2015 6:28pm
Disco_Mikey
Correct Thumbs Up
Cheapest and easiest place to start
Post #458856 Sat Apr 11 2015 7:45pm
zaphod
Thanks Disco_Mikey, been considering replacing my steering wheel with a Cherry wood one anyway so this could be a chance to kill two birds with one stone so to speak. Thumbs Up
Post #458904 Sun Apr 12 2015 8:42am
