Home > Maintenance & Modifications > Battery warning light help...
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hey guys.
Just when you start getting somewhere sorting out your general maintenance and get your loved vehicle running how you want....bam!....another one!
In my second day of my red battery warning light being illuminated.
First day was intermittent, today it seems to be staying.
I've had no starting problems though.
I've run the diagnostic screens and with the car running, charging is fluctuating between 12.5v and 13.0v.
Is this normal or is my battery light being illuminated due to this being too low?
I have no other error codes, is that strange?
I'm thinking alternator?.....
 I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #456779 Sun Mar 22 2015 2:10pm
Lost for Words
Hi Gaz,
Good to meet you yesterday, BTW, and good to hear the light's still not on yet. Smile
If it's now dropping down to 12.5 with the engine running then that confirms that the alternator is indeed the problem. Thumbs Up
Must have just caught it at a good time with the DMM. As your battery was at 12.68, it would appear to be good, so best to get the alternator done before it takes the battery out with it. Wink
Does it have ACE? Question
If it does, you want this one: http://www.advancedfactors.co.uk/dan-988-a...-424-p.asp
Or if not: http://www.advancedfactors.co.uk/dan-987-a...0-74-p.asp
Thumbs Up Visiting from DISCO3.CO.UK
Post #456780 Sun Mar 22 2015 2:26pm
Gaz
Yeah likewise.....great to meet you and your dad!
Yep.....I have ACE.
I'll take a look at the link now..... Thumbs Up
What should an alternator realistically be putting back in?
Gaz. I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #456781 Sun Mar 22 2015 2:37pm
Lost for Words
A good output will vary. Anywhere from the high 13s up to low 15s is OK. High 15s and up and it's too much. Low 13s downwards is bad too. Naturally, other vehicles vary (the 3.0 SDV6, for instance, charges at lower voltages). Wink
I would expect the voltage to be at the lower end of the good range as your battery seems good. That's why I thought the 13.7 or so I got from the multimeter was probably OK. As I mentioned, the diagnostic screen is really quite inaccurate (usually low, I think) hence not too worried about seeing 13 there but 12.5 is a definite problem. Thumbs Up
FWIW, our D3 (battery OK but could be better) charges at 14.2-14.5v. Wink Visiting from DISCO3.CO.UK
Post #456783 Sun Mar 22 2015 3:02pm
Gaz
Is changing the alternator with ACE that much harder than one without? I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #456785 Sun Mar 22 2015 4:00pm
Gaz
.....new ACE alternator ordered from Steve at Advanced Factors. Thumbs Up I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #456795 Sun Mar 22 2015 4:54pm
gogsy1956
at tickover mine puts out 14.7v so a replacement alternator seems to be your first move as you say ,,,, even though it may be a welcome one !! 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #456808 Sun Mar 22 2015 5:44pm
Gaz
Thanks Gogsy.....just need to make it until Saturday! Thumbs Up I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #456826 Sun Mar 22 2015 6:21pm
mnk
Gaz, how did you get your Nav screen display that test form?
Post #458678 Thu Apr 09 2015 12:05pm
Lost for Words
Lost for Words wrote:
On the Home screen press the centre top of the screen, roughly on the line, for 5 seconds then press the navigation hard button until a keypad appears. Enter code 753.
Note, the voltage is far from accurate (but it can still give a general idea).
I presume from your posts that you have an HDC fault message etc.? Question
If so, you will indeed likely find the battery and/or alternator to be at fault but the only way to get a true reading is using a multimeter at the battery directly. Thumbs Up Visiting from DISCO3.CO.UK
Post #458680 Thu Apr 09 2015 12:20pm
Gaz
EGR Blanked.
Post #458681 Thu Apr 09 2015 12:20pm
mnk
Correct, the engine has been turning a little slow over the last few weeks. However my brake sensors have activated and I will be changing pads and discs over the weekend. I will wait until then to see if it clears the gremlin.
Post #458683 Thu Apr 09 2015 12:32pm
Gaz
A dicky battery or alternator can give you a few odd gremlins and false faults remember.
Mine was just on the cusp I think.
I started getting some odd things flash up and the radio did some odd things too!
After the alternator change, all went away! Thumbs Up I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #458685 Thu Apr 09 2015 12:45pm
mnk
So do you think I should get the battery and alternator checked before changing my brake pads and installing new sensor. What should the voltage read at the terminals?
Finally how much did you pay to have the alternator changed?
Post #458689 Thu Apr 09 2015 1:23pm
Lost for Words
The alternator should be from high 13s to low 15s according to the battery's state of charge.
(Apologies if you already know this, but the battery should be left for a few hours to ensure allow the surface charge to clear before taking a reading.)
No need to hold back on the brake pads, once the sensors trigger, there's very little pad left so you can't hang around. Thumbs Up Visiting from DISCO3.CO.UK
Post #458690 Thu Apr 09 2015 1:33pm
