Home > Maintenance & Modifications > Brake caliper removal |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
Morning, so I had three days off, so what do you do, you change the front discs to slotted and drilled ones, painted black, repaint the calipers red ( Brembos fitted as standard ) and put in a new pair of pads. Good idea one may think, however when I came to the nearside wheel, the caliper bolts would not come undo, they cracked easy enough with a 600mm pry bar, but the bolts are just as tight 3 full turns later, and in fact seemed to be getting stiffer. After an hour of messing about, loads of wd40 and tightening/untightening I gave up and put it all back togeather, plus it had stated to rain
Wed Apr 01 2015 9:37am |
Something doesn't sound right, that's for sure.
Wed Apr 01 2015 10:30am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
Sounds like the threads have been damaged, and have picked up on the way out...
Wed Apr 01 2015 11:37am |
I was hopeing you would confirm that all I had to do was work it in and out for hours and hours and hours
Wed Apr 01 2015 1:15pm |
