Home > Technical > No Backlight on Speedo needle,
theGeMan
United Kingdom 2010 Range Rover Sport TDV8 HSE Zermatt Silver
so have a small issue with the speedo needle, it no longer lights up! its just this needle everything else on the instrument display is as you would expect rev counter, all the numbers round the speedo are fine, needle still moves.
could this just be a bad connection, is there anything i can check or is it off to the dealers?
Post #447581 Tue Jan 06 2015 7:12pm
theGeMan
just an update, must be a bad connection / dry joint as it came on for 1/2 the journey today before going out just as i parked up,
expect the fix would be a new instrument cluster.
Post #447736 Wed Jan 07 2015 7:57pm
idrabble
Australia
"expect the fix would be a new instrument cluster."
or a new bulb maybe.
Post #447778 Thu Jan 08 2015 3:00am
Siddharthaoke
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Galway Green
Mine does this too (2010 my hse). When it's cold much more noticable as it flickers on and off. As the car warms up the needle flickers from dim to bright and after about 30 mins its normal and no more flickering. Unsure of the cause. I would have assumed a dry solder would have been off or on not flickering dim and bright in between, but unsure, and odd that it's a lot more noticable when it's cold and less so when it is warm.
Could it be a voltage thing?
Sid
Post #448888 Sun Jan 18 2015 8:03pm
theGeMan
Yes seams like the same fault, it's had a quick look by a local independent who are going to look at getting the unit repaired if not its a new cluster from Land Rover,
it needs sending off for a couple of days so not getting it done just yes as need the car.
* just to add mine seams to be off much more then on at the moment. Good two hr drive the other day and didn't come on once, but was flickering today.
Post #448966 Mon Jan 19 2015 1:22pm
Siddharthaoke
theGeMan did you manage to get this sorted?
Post #457593 Mon Mar 30 2015 9:13am
p.johnson1981
Hi did you ever find the problem? Im have the same problem on my Discovery 4 (61 plate)
Post #616971 Thu Sep 02 2021 12:29pm
gogsy1956
This is a very common problem,, flickering speedo or rev counter needles. Cheapest option is to send it off to an outfit called totaltronics,, have a look at their website for more details. This isn't a Diy fix and a dealer would sting you for a new cluster,,, if you are close enough they can remove and fix the cluster while you wait. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #616980 Thu Sep 02 2021 6:45pm
