Home > General > A bit of advice pls
Simon B
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Java Black
Yes I am a bit hacked off to say the least, it may not even be somone from here, I like this site alot and don't want to go pointing the finger, I should blame myself lol. Anyway the search continues and thanks to all for advice.
Post #456997 Tue Mar 24 2015 7:37am
Tim in Scotland
There are lots of well looked after RRS's for sale out there so don't get disheartened, just remember that there is no such thing as a "bargain" RRS - good ones are expensive and cars with low looking prices are usually expensive to repair to make run well - why else would someone sell one cheaply? All Land Rover prodcuts benefit hugely from TLC from people who know how they work and suffer quickly if services are missed or faults not fixed quickly - they are hugely complex machines. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #457005 Tue Mar 24 2015 9:33am
Paddi
Get yourself and your cheque book up to Sotland
http://www.rrsport.co.uk/forum/topic39736.html 2008 MY Java Black TDV8 HSE
Post #457051 Tue Mar 24 2015 6:19pm
Simon B
That's a nice car but alas too old for me, I'm after the newer interior.
Post #457053 Tue Mar 24 2015 6:51pm
Simon B
Well, today's news is that it's bot sold now and it's mine to look at, so guys what do I look for in the test drive ?
Post #457226 Thu Mar 26 2015 11:37am
Russben
It should be nice & smooth to drive, gear changes should be smooth & quick. No black smoke when you put your foot down (stuck or gummed up EGR valves can cause this). It should drive straight. On a slightly uneven road at low speed there should be no thumps or rattles from the front suspension (worn antiroll bar bushes cause this, especially on models with 'Dynamic' setting on terrain response). Try 'dabbing' the brakes at low speed to test for worn bushes, you'll hear a knock if they are.
Brakes should be powerful with no pulling or jerkiness. All electrics should work & there should be no warning lamps on dash once engine is started.
Suspension should go down & up again quickly with no warnings on dash. Press suspension down button, car should drop the front end first, wait for it to settle then press it up again, wait for it to level out & press it up again into 'off road' height. Car should raise back end first (to avoid headlamps dazzling other road users at night). Press the infotainment screen to 'menu' & then '4x4' & have a look at the little line above each wheel on the screen, it should be white line IIRC. A red line could indicate a fault with that wheel sensor.
Some of the above is obvious really, so apologies & no offence intended.
I'm sure someone else will be along soon with more advice.
Good luck. Thumbs Up I'm in the shed, I'll be back in the real world in a minute.
Post #457227 Thu Mar 26 2015 11:57am
Simon B
Thank you that's brilliant
Post #457238 Thu Mar 26 2015 1:33pm
Simon B
Well, I did all those checks and more and the car is just perfect so perfect I brought it and have now had it all weekend and it's just awesome, I'm so pleased. Thanks again guys for your help and advice and I look forward to useing this site a lot more for useful stuff.
Post #457527 Sun Mar 29 2015 4:37pm
fdhadi
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Enjoy Thumbs Up
Post #457569 Sun Mar 29 2015 10:07pm
Russben
Enjoy Thumbs Up I'm in the shed, I'll be back in the real world in a minute.
Post #457616 Mon Mar 30 2015 10:30am
Simon B
Thanks
Post #457629 Mon Mar 30 2015 11:54am
