Home > Maintenance & Modifications > Knocking noise
ljw350
Knocking noise
First off, sorry I know there are lots of threads on this but can't fine what I'm looking for.
I have a TDV8. I get knocking noise when going over bumps and also when I brake hard.
Anyone know what bushes could be gone or best way to check? I changed the drop link (stabiliser bars) and no different
Thanks lee
Post #457423 Sat Mar 28 2015 2:19pm
RogerDeFlor
This is from the buyers guide...
The sport is prone to development of knocking noises from the suspension. Knocks when travelling over badly maintained road surfaces usually indicates worn anti-roll bar bushes. Knock on sharp braking from low speeds suggests worn suspension lower arm bushes. Where ‘Dynamic response’ also sometimes referred to as ‘Active Roll Control’ is fitted (standard on the TDV8) careful inspection of the hydraulic actuators situated in the middle of the anti-roll bars for leaks is essential; look at the seal where the anti-roll bar exits the actuator; dampness is normal but any drips probably indicate complete replacement is required and a single unit costs around £900 plus fitting. Leaks from the hydraulic pipe unions can usually be rectified by replacing the ‘O’ rings in the union.
Hope it helps diagnose the problem
Rob
Post #457439 Sat Mar 28 2015 4:46pm
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
....ARB bushes.
Had mine replaced front and back.....no more knocking. Thumbs Up I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #457446 Sat Mar 28 2015 5:41pm
ljw350
thanks for the help. Hopefully change this week
Post #457498 Sun Mar 29 2015 7:42am
