![]() | Home > Technical > headlamp adjustment |
Martin0711 Member Since: 25 Jan 2014 Location: Buckie Posts: 45 ![]() ![]() ![]() |
Open bonnet, look behind headlight unit and on the inner most side of the headlight you will find an Allen key adjustment screw. If I rememer correctly turn ain't clockwise to bring the beam up.
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1827 ![]() ![]() |
Great thanks Martin. SVR 2018 in Santorini Black. |
betarr400 Member Since: 28 May 2017 Location: roma Posts: 10 ![]() ![]() ![]() |
The brucs are two ...... for the lighthouse |
BJH1959 Member Since: 25 Mar 2017 Location: Paredes de Coura, Portugal Posts: 410 ![]() ![]() ![]() |
Is this just for height adjustment or does the same work for driving in Europe? Barrie.
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
Thanks Socast. |
stagfinder Member Since: 17 Dec 2015 Location: Peterborough Posts: 22 ![]() ![]() ![]() |
for europe there is a small lever that moves up and down at the side of the bulb holder what it does is flaten the beam for europe if that helps |
Thanks Stagfinder. I found the lever after viewing Socast's video but thank you for making the time to reply. |
