![]() | Home > Technical > Default Audio volume |
Lateral5 Member Since: 07 Jun 2006 Location: Down south Posts: 331 ![]() ![]() |
hi all,
Black Sea Member Since: 18 Jul 2006 Location: Black Sea coast Posts: 5 ![]() ![]() ![]() |
I have the same problem. No solution for that? |
Mine always comes back on at the same level I turned it off at, I'm sure. |
MDP Member Since: 14 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
So does mine. |
I do not expect that everybody from the forum to inform us that they have not this problem. Is any solution to solve that? |
It shouldn't do it - so I suggest a dealer visit for a software upgrade is needed. |
Yes, but if enough people tell they do not have this problem and nobody suggests a remedy, at least you'll know its time to visit your dealer... ![]() ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Thank you for the suggestions. I will go to the delear next week. |
I took mine in week before last for a few other things and asked them about this. The guy told me you can do it via the system menu and he would look at mine. Well guess what, I got the car back and it is no different.....so I guess you would say that is no solution |
Zipperman19 Member Since: 22 Aug 2005 Location: South Florida Posts: 85 ![]() ![]() ![]() |
I think the reason that it stays for some people and not for others is because there is a volume range where it will not change the volume by itself. For instance if it's set above 20 it will default to 20, and if it's set below 7 (i think) it defaults to 7. I think that's how the radio works. Atleast for mine. |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
I think it is one of the system settings. I can't remember exactly what it is but it is something like "Source Tone Memory" - On or Off.
Mmmm...I've just been out and checked and I was right about the setting name, but it doesn't seem to have any effect on the stored volume level. However, I can confirm that mine does turn on at the previously set volume.
Is your volume number between 7 and 20 beacause if so, it will come back on at the correct volume. Try putting it to 25 or 5 and see what it comes back on as. |
Level 7 on mine is very low and I can't imagine having to turn it "down" from level 7. I would have to turn it up. Paul |
