Home > Technical > Emergency access when the key fob/ battery goes flat
Tim in Scotland
Ever wondered what the little lock symbol on your passenger side door handle trim is for?
Next time you are round that side of the car bend down and look under the handle and you will see a keyhole on the base of the fixed plastic trim. Inserting the ignition key will unlock this cover exposing an emegency lock for overriding the cenral locking system. It will set off the alarm if you open the door but at least you will be able to get in and disable that and start the engine using the key, the key fob battery will recharge as you drive along.
The instructor at LRE Dunkeld showed me this yesterday.................. and we had a lot of problems getting the cover back on, so if you are going to experiment with yours be very careful when replacing the lock cover as it is easily damaged and is quite fiddly to replace 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #4571 Wed Nov 02 2005 10:23am
gregpen
2006 Range Rover Sport 4.4 V8 HSE Zambezi Silver
Thanks for that wonderful nugget of information. I was similarly wondering why that lock symbol was there. Now I know. Thanks! Wink
-Greg
Post #4573 Wed Nov 02 2005 10:28am
I do remember briefly reading something somewhere? But as useual Tim, you have enlightened us all.
Keep up the good work
Post #4575 Wed Nov 02 2005 10:31am
tasmod
United Kingdom 2006 Range Rover Sport TDV6 HSE Rimini Red
Post #4582 Wed Nov 02 2005 11:34am
No I did'nt see the black doorhandles??
Rob where on ebay are they? Do you have a link ?
Martin
Post #4588 Wed Nov 02 2005 12:10pm
Ha Ha... Now found them on USA ebay here is the link
http://cgi.ebay.com/ebaymotors/Land-Rover-...QQtcZphoto
Interesting Confused
Post #4591 Wed Nov 02 2005 12:52pm
