Home > Maintenance & Modifications > TDV8 front pads advice
austencameron
Brembo front pads or not? My last set have squealed from new and are now fit for a change, any advice would be great
Post #457074 Tue Mar 24 2015 9:20pm
JK07
Australia 2012 Range Rover Sport 3.0 TDV6 SE Fuji White
Brembo brakes are not as good as they used to be.
I have tried pretty much all the brands in various cars I have. But right now Bendix are the best brake pads you can get and are excellent quality. LR should be using them instead.
Post #457082 Wed Mar 25 2015 12:45am
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
im going to do my s/c do you have a link for suppliers Thumbs Up
Post #457085 Wed Mar 25 2015 4:35am
JK07
I am doing the same. But changing all front and rear brake pads.
After a lot of research and past history I found Bendix Brake Pads are the best.
Bendix Rear Brake Pads Part Number BENDIX DB1781-4WD
http://www.ebay.com.au/itm/121351537823
Bendix Front Brake Pads Heavy Duty BENDIX DB2073-HD
http://www.ebay.com.au/itm/121311981348
Bendix Rear Brake Park Shoes BS5097
And for the Brake Rotors i found the best are Australian made DBA T2 slotted rotors.
DBA2096S $325.00 pair
DBA2096X $580.00 pair
DBA2095S $254.00 pair
DBA2095X $290.00 pair
DB1780WB $88.00
DB1781WB $88.00
Post #457086 Wed Mar 25 2015 7:46am
