![]() | Home > Technical > LED TAIL LIGHT FAULT |
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
Have you checked the terminals?.....may have a corrosion problem or an iffy contact.
Marti1975 Member Since: 23 Mar 2015 Location: Glasgow Posts: 4 ![]() ![]() ![]() |
I had the lamp unit completely off the car and unplugged
.....sounds like a wobbly cable in the back of plug socket.
andynpz Member Since: 20 Sep 2014 Location: Cotswolds Posts: 49 ![]() ![]() ![]() |
You might want to check the earthing point nearest to the offending tailight. Usually it's like a captive bolt with several wire terminals and a nut holding them on - worth cleaning up any corrosion. 2011 TDV6 HSE Stornoway grey, ivory trim
It's the full unit with the led's built in doesn't look aftermarket and not individual bulbs. I will check in the morning take the unit out again and look at each wire Cheers |
Thanks for that tip I will take the unit out tomorrow and trace the wires back to find an earth point. ![]() |
