Home > Wheels & Tyres > Which are the correct wheels for RRSPORT TDV6 2.7 2005?
TOELPEL
Spain 2005 Range Rover Sport TDV6 SE Buckingham Blue
Bow down Which rims are approved for my RRSPORT 2005? The COC says 18", the car had 20" when I bought it. Does range zrover specifies certain size of rims to be legal?
Thanks for any reply . Bow down
2005 RRSPORT 2.7 TDV6
1997 RR
1983 RR
1978 RR
Post #456731 Sun Mar 22 2015 4:47am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Hola Toelpel,
For 20 inch wheels, the car needs officially to be equipped with the dampened steering rack to prevent vibrations due to the bigger rim size.
However, I installd 20 inch on my 2005 Sport without the dampened rack and had no vibrations nor problems with it.
Greeting from Marbella!
SW. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #456890 Mon Mar 23 2015 9:14am
TOELPEL
Hola Sky Walker.
Thanks for the info. What is the ITV in Spain requesting? Has Range Rover approved certain rim sizes for this car?i appreciate further comments. Thank you.
Post #456929 Mon Mar 23 2015 3:07pm
SkyWalker
ITV makes no problem of the bigger rims, since this size was standard on other RRS versions (RRS SC).
The only thing is that LR recommends a dampened steering rack. SW
Post #456945 Mon Mar 23 2015 5:32pm
TOELPEL
Thanks Walker I'll see what happens. Anyway I have something to defend if in need.
Post #456946 Mon Mar 23 2015 5:36pm
riverblanche
hi Toelpel
255.50.19 are a standard fit
and here are two different styles that are standard Whistle
http://www.rrsport.co.uk/forum/topic39673.html
Post #456985 Mon Mar 23 2015 10:42pm
TOELPEL
Thanks Riverblanche. My COC states as correct rims 8Jx18x53 and for the tires 255x55x18
Post #456987 Mon Mar 23 2015 11:52pm
