![]() | Home > Technical > Juddering at 70mph |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
Just the front wheels or the whole car? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Chado Member Since: 09 Apr 2014 Location: Sheffield Posts: 10 ![]() ![]() ![]() |
The whole car judders, it was the front wheels I've had balanced. |
Try having all the wheels balanced. This can be very tricky to solve. My 2008 had:
You don't,say what mileage is on your sport, but as you have already tried, wheel balance or even 4 wheel alignment is the first route to go down. After that, if you have a higher mileage car the torque converter could be the problem. I believe it,s referred to as the cattle grid effect, because it's just like driving across one.
Jay2012 Member Since: 01 Jul 2012 Location: Uk Posts: 21 ![]() ![]() |
Do look at the vibration posts, but.. Sometimes the simplest things work.. I had same issues, LR replaced half shafts; and considered propshaft.. However, it turned out to be wheel balance! They were balanced by a specialist and the vibration went. The dealer found this by trying a different set of wheels before ordering all the prop parts suggested by LR.. Good on them. So, if possible try that too |
Minshy Member Since: 06 Jun 2014 Location: Mottram Posts: 48 ![]() |
I had same issue. It turned out to be water in one of the back wheels. Tyre guy said never ever seen that before.
It was water in both back tyres! Not sure how it got in there - anyone know? |
Water could get into your wheels from the airline if the garage you use hasn't drained there compressor and don't have a water trap. 2008 G4 RRSport TDV8 current
Gaz Member Since: 19 Oct 2013 Location: Bristol Posts: 246 ![]() ![]() ![]() |
.....warped brake discs maybe? I was born with a photographic memory. Shame it didn't develop!
Camelrock
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() |
Could the water be from a pressure washer? You'd have to hold it close to the tyre bead for a while, admittedly. I'm in the shed, I'll be back in the real world in a minute.
Hi chaps,
Htailor23 Member Since: 01 Jan 2014 Location: London Posts: 7 ![]() ![]() ![]() |
Papa kilo Member Since: 17 May 2015 Location: Preston Posts: 3 ![]() ![]() ![]() |
