![]() | Home > Technical > Towing Electrics |
Blake Member Since: 16 Mar 2015 Location: Wiltshire Posts: 3 ![]() ![]() |
Hi all,
did you run the cables through the light or did you run it just above the exhaust?
itsmeagain Member Since: 01 Nov 2012 Location: Birmingham Posts: 222 ![]() ![]() ![]() |
Thru the hole behind the light, took about 50 minutes to do Current 2010 Range Rover Sport HSE with the usual toys: timed climate, Rosen headrest screens, tow bar with twin electrics, Blackvue HD cam
