Home > General > Ride height lowered
Andyjay123
Ride height lowered
Has anyone had their ride height electronically lowered by 25mm?
If so where? How much? Does it affect the comfort?
Many thanks 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #455769 Fri Mar 13 2015 9:02pm
mnk
I have mine lowered by 23mm all round, comfort is fine/almost unchanged.
PM me if you want it electronically done via diagnostic.
Post #455770 Fri Mar 13 2015 9:09pm
Bodsy
Site Sponsor
Andy,
Some can be lowered by 30mm, others by only a few mm, it depends on the calibration of the sensors.
I can do it when I reset your gearbox Thumbs Up
You'll need to have the suspension re-aligned afterwards to avoid excessive edge of tyre wear. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #455771 Fri Mar 13 2015 9:44pm
Andyjay123
When are you around?????? 😛 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #455772 Fri Mar 13 2015 9:49pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
why would you want to lower it ?
Post #455779 Fri Mar 13 2015 11:36pm
sagalout
This! ^^
Makes no sense - just buy a car!
Post #455781 Sat Mar 14 2015 12:12am
Andyjay123
Because I can 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #455784 Sat Mar 14 2015 2:25am
sagalout
I take it back - looks awesome Wink
Post #455793 Sat Mar 14 2015 9:39am
zaphod
Lol that's insane... Gotta be a photoshop job though surely ?
Post #455796 Sat Mar 14 2015 10:24am
Disco_Mikey
I once lowered an RRS 55mm. Customer wanted it as low as possible in "Normal" ride height
He done less than 10 miles and came back to have it put back to normal Laughing
Post #455800 Sat Mar 14 2015 10:54am
Bodsy
Site Sponsor
Lol not surprised! 50mm drop at standard height is a lot. I take it he wasn't bothered about using access height. Bodsys Brake Bible
See it HERE
Post #455802 Sat Mar 14 2015 11:18am
SRE
Spain
Played with mine, however back to standard now, also remember if you lower the standard ride height, then you could have an issue if you reach a 100mph as the vehicle automatically lowers 20mm. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #455820 Sat Mar 14 2015 3:12pm
jimbg
Does it really do that? 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #455822 Sat Mar 14 2015 3:16pm
From the manual:
Quote:
High Speed Mode
High speed mode is a non-selectable, automatic mode which lowers the vehicle height by 20mm to improve vehicle handling. This
feature is fully automated and is 'invisible' to the driver.
If the vehicle speed exceeds 100 mph (160 km/h) for more than five seconds, the air suspension control module initiates the high
speed mode. When the vehicle speed reduces to less than 80 mph (130 km/h) for more than 30 seconds, the vehicle returns to the
On-Road height. This function is cancelled if a trailer is connected to the trailer socket.
 2012 SDV6 - it's missing a couple of cylinders
Post #455838 Sat Mar 14 2015 5:43pm
If you want to be able to vary your ride height at any speed then you could look at something like this:
http://www.mudtech4x4.com/modulo-sospensio...t/?lang=en
That link is for a unit that allows you to select varying heights below standard. They do a unit that allows you to select increased off road clearances too.
http://www.mudtech4x4.com/modulo-aggiuntiv...s/?lang=en
I'm quietly tempted by the latter unit but it's a lot of £ for something that currently won't get enough use. 2012 SDV6 - it's missing a couple of cylinders
Post #455839 Sat Mar 14 2015 5:50pm
