![]() | Home > Faults & Fixes > transfer case ecu water corroded the connections |
alex3357 Member Since: 09 Mar 2015 Location: Bayton Posts: 10 ![]() ![]() ![]() |
Hi Everybody
Hi Paddi
Thanks Alex,
Thanks Alex,
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9014 ![]() ![]() ![]() |
The transfer case control module lives in the e-box that houses the engine ECU. It's behind the battery box. If the transfer case module is showing signs of water ingress then make sure that the engine ECU isn't also getting wet. Trace where the water is coming from and how it's getting in to the e-box. 2012 SDV6 - it's missing a couple of cylinders
