Home > General (L494) > Fuel consumption |
Nowaytk Member Since: 27 May 2013 Location: London Posts: 183 |
Right, as there have been LOADS of guessing going on I thought I'd just post up a screen shot of the incontrol info and see what you make of it. I'll be doing the return trip later today so as I will be driving some would say " normally " I will also post another screen shot of that trip to show what the difference is. So here goes, don't all laugh at once
Tue Feb 10 2015 9:43am |
Ok, so just to update, return trip shorter distance and time due to stopping at services but still had to go through the 50mph avg speed section, this time driving my normal style for m ways which is nearer the unofficial speed limit at times + some,
Tue Feb 10 2015 6:02pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Lucky You 70 Litres of Derv over here cost £79 itisme |
Wed Feb 11 2015 9:47am |
So guys, with the mpg that the car is showing, do I assume right that I would need to at least take off 10 mpg ?
Wed Feb 11 2015 9:11pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Roughly 8-10% off MPG. 2014 L405 SDV8 RR Autobiography
Wed Feb 11 2015 10:15pm |
peanutbob Member Since: 04 Jul 2011 Location: UK Posts: 585 |
My thoughts are that it is a completely useless software application What on earth is the point of it when the readings are way out of kilter? |
Wed Feb 11 2015 10:53pm |
malcolmw Member Since: 05 Dec 2013 Location: United Kingdom Posts: 122 |
So, can it be recalibrated? Can a dealer do this? Regards
Thu Feb 12 2015 7:36am |
I cant see what all the fuss is about. The only true reading you need is fuel gauge. When its getting low fill it up. I was always told if you have to worry about how much MPG it does. You cant afford it itisme Last edited by harrygh60 on Fri Feb 13 2015 8:31am. Edited 1 time in total |
Thu Feb 12 2015 8:32am |
That's exactly what I do, it gets low so I fill it up it's because of the incontrol I can now look at things on the sofa, and when I saw some fairly high mpg readings for a SDV6, I decided to see what I could get it up to as I was in no hurry so thought why not. Just out of interest what are you getting out of your supercharged 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
Thu Feb 12 2015 4:57pm |
simonsti Member Since: 29 Apr 2006 Location: staffs Posts: 193 |
I've had a true 41Mpg on a steady 300 mile motorway trip. 2014 Nara Bronze SDV6
Thu Feb 12 2015 8:29pm |
[quote="Nowaytk"]That's exactly what I do, it gets low so I fill it up it's because of the incontrol I can now look at things on the sofa, and when I saw some fairly high mpg readings for a SDV6, I decided to see what I could get it up to as I was in no hurry so thought why not. Just out of interest what are you getting out of your supercharged [/quote
Fri Feb 13 2015 8:37am |
Hugh Haddow Member Since: 03 Jul 2009 Location: Prestwick Posts: 202 |
Report post
Mon Feb 16 2015 12:13pm |
Come on guys you aren't even trying.................... according to the InControl in my Evoque 9 speed auto my best trip average so far is 90.2mpg. I use the Fuelly website to monitor every tankful of fuel though and that gives a more realistic figure. In almost 12 months and 7300 miles Fuelly reckons my Evqoue has achieved an average of 39.3mpg with a tankful best average of 43mpg.
Fri Mar 13 2015 8:44am |
So what did the feully site say your average was ? On my evoque I didn't reset the dash trip for over 10,000 miles (it zeros itself at 10k) and that said 29.2, so I was likely getting less than that , you must of been when you saw 90.2, unless of course you knew about that really BIG hill you were coasting down 2015 HSE SDV6 Scotia Grey, ebony / lunar, colour coded, deployable steps, TV, sliding pano and a few other bits. Now gone
Fri Mar 13 2015 8:54am |
