PDC - Beeping Stays on too long
Hi Folks
I'm a new RRS owner and new to the forum and was wondering if you might be able to offer a bit of guidance on an issues having with the PDC system.
All of the posts I've been able to find on the forum relate to the early models and the technical bulletin relating to replacing the ECU when customers complain about unsatisfactory operation. My VIN falls outside of the range specified, it's a build date July 2006.
The problem is, say you reverse up to a wall and it works fine, beeping until you're close then continuous beep. Stop, then put into drive and pull away from the wall - it continues to beep for some seconds after. Pushing the button on centre console stops it as well. In all other respects, the system seems to be happy enough but all of the reversing sensors I've had before will stop beeping when you select park or drive.
Any help or guidance would be much appreciated.
Regards
Barry
Tue Mar 10 2015 1:49pm
Nigt3
Mines does exactly the same, really annoying!!
Tue Mar 10 2015 2:59pm
LandPhil
Even though you are driving forwards, away from the obstacle, it will still beep until the wall is out of range.
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
