Home > Maintenance & Modifications > New stainless steel paddle shifts fitted.
Bodsy
Site Sponsor
If you're not replacing existing paddles, (i.e. you are adding new functionality) then you will also need the wiring loom fitted and enabling on the car. Thumbs Up
But if just swapping over to these, then straight forward as ABSport says. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #454893 Fri Mar 06 2015 3:25pm
Violetpiano
Many thanks ABSport Thumbs Up Current RRS: MY18 SVR
Previous RRS: MY15 RRS 5.0L Autobiography
Post #455127 Sun Mar 08 2015 3:57pm
Andyjay123
I don't have paddles, is this something i can fit after market? 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #455143 Sun Mar 08 2015 5:19pm
Bodsy
Site Sponsor
Andy, yes that's right. Switches and loom, then needs enabling. Thumbs Up Bodsys Brake Bible
See it HERE
Post #455144 Sun Mar 08 2015 5:30pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Bodsy is your man Thumbs Up I met up and it took 5 mins.
Post #455145 Sun Mar 08 2015 5:32pm
Andyjay123
Can you quote tosupply and fit Ian? I would not want standard paddles 😛
07876 563 155
Thanks 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #455164 Sun Mar 08 2015 7:13pm
ABSport
AndyJay123
If you do not currently have paddle shift, you will require the back panel on the steering wheel for the "cut outs" for the paddles to sit. This is relativly cheap from Land Rover. You will also require the wiring harness its about £30 from Land Rover. The Paddles I have fitted the part number is VPLVS0187MMU they are genuine Land Rover Parts and cost £320 Big Cry Shocked
Once you have these fitted Ian will be able to enable them for you Thumbs Up
Post #455173 Sun Mar 08 2015 7:51pm
raheelc
United States
New member here. Could someone point me in the right direction to where I can buy the back cover for the steering wheel, that has the cutouts for the paddle shifters? I want to add paddle shifters to my 2010 RRS, but I haven't had any luck sourcing the back cover that has the cutouts.
Thanks!
Post #483441 Tue Dec 29 2015 4:05am
