Home > General > Jacking Adapter |
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 |
I need one too |
Thu Mar 05 2015 12:23am |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 |
I'm interested also. |
Thu Mar 05 2015 5:30am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
The real problem with the provided jack is not so much getting it up in the air, but when it gives way. Note to all: Do not trust the provided jack. I have the Clarke jack you mention and have been meaning to get hold of an adapter for it. It works fine without one though so don't wait to get one for that though. Since I rarely use the actual jacking points, I suppose it would not be of much use to me anyway. Would be a good idea to get a bottle jack to keep in the car too. Visiting from DISCO3.CO.UK 2006 Discovery 3 TDV6 Auto HSE Zambezi Silver |
Thu Mar 05 2015 8:50am |
bonzer Member Since: 16 Mar 2016 Location: Staines Posts: 33 |
Hi All,
Mon Aug 21 2017 8:05am |
Scrumpy Member Since: 11 Nov 2016 Location: Surrey Posts: 567 |
Mon Aug 21 2017 8:22am |
ive got a proper lift or 3
Mon Aug 21 2017 10:15am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Jack it up under a wishbone front or rear using a trolley jack or a decent bottle jack.
Mon Aug 21 2017 11:37am |
As DrRob says
Mon Aug 21 2017 12:23pm |
The OP could take a copy of this drawing to a local engineering shop and request they make him one up in stainless, aircraft grade aluminium or boring old steel. If he was to have several made there is a healthy demand on this forum.
Mon Aug 21 2017 1:04pm |
SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329 |
Now that is one clean Jack Paddi, not seen much use. Have you had it detailed its cleaner than my car In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Tue Aug 22 2017 8:02am |
Sadly those pictures were plagiarised from an old Disco 3 thread. Be assured my own 3 ton SGS trolley jack is covered in dust dirt and grease just as it should be. 2008 MY Java Black TDV8 HSE
Tue Aug 22 2017 1:02pm |
W55*** Member Since: 01 May 2015 Location: Derby Posts: 7 |
Beware of cheap alloy ones that are prone to snap apparently. |
Wed Aug 23 2017 10:26pm |
