Home > In Car Electronics > Microphone - noise cancelling?
Paddi
Is the microphone supposed to have noise cancelling?
If it is then mine sure ain't working because callers can instantly perceive that I'm in the car.
Is there a compatible noise cancelling mike that can be fitted? Something like this: http://www.amazon.co.uk/CLARION-RCB199-Ext...B0013BW96S 2008 MY Java Black TDV8 HSE
Post #454516 Tue Mar 03 2015 3:03pm
Bodsy
Site Sponsor
No it's not.
It's just a two cable Microphone, has no intelligence in it. Not sure if that would work or not, but would be interested if it does.
The D4 BT module is much much clearer for both you and the caller if you retrofit it for the existing one. Just requires two male to female wired pins (oh and a D4 module of course.
Cost of the module is about £240ish
I found that the older module you could always tell you were in the car, the newer module, people couldn't believe you were in the car. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #454520 Tue Mar 03 2015 3:28pm
Andyjay123
Ian can I have a gear box reset please?
Andy Wimbledon 2006 RRS Supercharged 4.2 HST muthuaflecka!
Post #454524 Tue Mar 03 2015 4:27pm
Bodsy
Site Sponsor
Yes Andy, no problem.
I have you noted in for my next trip down. Thumbs Up Bodsys Brake Bible
See it HERE
Post #454529 Tue Mar 03 2015 4:44pm
Paddi
Thanks Bodsy. Had a feeling you might know the answer to that one!
I'll save up for the D4 module then. 2008 MY Java Black TDV8 HSE
Post #454535 Tue Mar 03 2015 5:05pm
Bodsy
Site Sponsor
Paddi, if you want to go that route, I may be able to do you a deal. Thumbs Up Bodsys Brake Bible
See it HERE
Post #454536 Tue Mar 03 2015 5:15pm
Paddi
I can rarely resist a deal Bodsy. Thumbs Up
Would you like to PM me with the details? 2008 MY Java Black TDV8 HSE
Post #454646 Wed Mar 04 2015 3:51pm
Bodsy
Site Sponsor
Thumbs Up Thumbs Up Bodsys Brake Bible
See it HERE
Post #454648 Wed Mar 04 2015 3:58pm
