![]() | Home > Faults & Fixes > Will not start! HDC FAULT, TRANSMISSION FAULT on dash |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
Any chance the brake pedal moved when fitting the brake switch?
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 ![]() ![]() ![]() |
Fuel pump belt is right at back of engine bay between engine and bulk head. Right bastard to reach. That may not be it but if the belts snapped then obvs no fuel |
Oh dear ![]() I think you need to get someone to look at the car, even plug it in and check for any fault codes. It may be something simple, such as a loose wiring connection someplace, up to a broken cambelt... |
ed68 Member Since: 15 Feb 2015 Location: Kent Posts: 14 ![]() ![]() ![]() |
thanks for the replies everyone
It looks as if not everyone offering advice has noticed your model is the 4,4V8 petrol.
Yep I presume (for no aparent reason) that your motor was a Diesel engine. Apologies. |
As did I |
Thanks for bringing that up Paddi, yes it's petrol i'm afraid everyone
Philwil Member Since: 28 Feb 2015 Location: Manchester Posts: 5 ![]() ![]() ![]() |
Hi, interested to read your story, I have similar problem and mine won't start either!
#What's your latest news PADDI?# apologies I meant to ask ed68 |
ok so it turned out to be a petrol pump problem why it was not starting, it seems the warning messages on the dash were not related at all, just a coincidence it happened all at the same day
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 ![]() ![]() |
I also had error messages on dash, called LR and booked car in. Was told the battery is low and they charged it overnight. Now no errors and it starts much faster. |
