Home > Faults & Fixes > Power steering fluid leak |
mnk Member Since: 25 Nov 2013 Location: United Kingdom Posts: 231 |
Hi
Tue Mar 03 2015 9:27am |
Steviesport Member Since: 15 Jun 2014 Location: North Lanarkshire Posts: 52 |
Ta for reply ....will it involve taking battery / box out cant see mucb underneath or what else do i need to take out ? |
Tue Mar 03 2015 9:44am |
I didn't have any leaks but the steering was really stiff, LR changed the shaft for me and fixed the problem. Spoke to someone else and they said shaft failure is common on this vehicles. |
Tue Mar 03 2015 9:53am |
I can see it dripping down hose front off turbo area, ive no idea what is in that Position below power steering resiviour hose from it looks kinked going down .nothing but problems after this engine replacement . |
Tue Mar 03 2015 10:03am |
Vaz Member Since: 09 Feb 2015 Location: London Posts: 10 |
Yeah best thing to do is to get your steering shaft checked out. |
Tue Mar 03 2015 1:04pm |
Assuming it really is a leak from the power steering (should be possible to tell by checking the level in the reservoir):
Tue Mar 03 2015 1:56pm |
All levels seem fine , in with Indy garage twice seems pentland edinburgh made a right arse fitting new engine all hoses required re routing ,still leaking after first attempt just collected car and can't bare to look under car.
Mon Mar 16 2015 11:04pm |
