![]() | Home > My Range Rover Sport > Shiny tailpipes on 11-reg TDV6 HSE |
Chris day Member Since: 31 Oct 2013 Location: Bexley kent Posts: 91 ![]() ![]() ![]() |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
No need to crawl around under car to get spare wheel off. Just unwind winch enough to drag wheel from under car. To fit the Anti Theft thingy just get enough surplus on cable to slide the tube in place,and put retaining washer on ![]() |
362bkr Member Since: 06 Dec 2013 Location: devon Posts: 856 ![]() ![]() ![]() |
. RESULT ! ![]() |
andynpz Member Since: 20 Sep 2014 Location: Cotswolds Posts: 49 ![]() ![]() ![]() |
The cable was way too short to get the wheel clear - I might try again but it unwound smoothly and came to a definite stop, despite a couple of heaves, no further movement. thanks for the advice ..... I will try again! 2011 TDV6 HSE Stornoway grey, ivory trim Life's too short to drive an ugly car. |
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
I don't mean to sound patronising but make sure your wheel is the right way round. It should be stored with the outside spokes facing up towards the bottom of the car. The 'dished' inside of the wheel should be facing down & getting road crud thrown onto it.
Good thought and not at all patronised! But wheel is outside up.
craig51 Member Since: 19 Feb 2015 Location: Edinburgh Posts: 13 ![]() ![]() ![]() |
Anti theft. Does a MY11 car need this to save the wheel getting knicked?
Garage Door Medic Member Since: 02 Feb 2014 Location: North West of UK Posts: 197 ![]() ![]() ![]() |
I have a MY13 and I've got one, but cable has been re-designed, and makes me feel better MY 13 3.0 SDV6 HSE Black Edition
I am not sure wether this is a landrover modification,or if someone has come up with a good idea. I was given mine by a friend who was asked to fit a dish type protector,so it did not need this part. It is suitable for all models. It is a toughened tubethat slides over the spring part of the cable that hangs below the wheel.it is held in place by a special washer. It prevents the ![]() ![]() |
