Home > General (L494) > Lane Departure System, Auto Dimming Headlights, TPMS |
mikef Member Since: 16 Sep 2013 Location: bucks Posts: 313 |
The High Beam Assist headlights can be switched on via the menu in the instrument panel and using the steering wheel controls. The TPMS tyre pressures can be viewed in the same menu system but only with the ignition on and the engine off. For some inexplicable reason you cannot access the screen to read the tyre pressures when the engine is running. I've had a few cars and indeed a couple of motorbikes with TPMS and all of them would allow you to monitor the tyre pressures on the move but it seems that this is beyond L-R
Mon Feb 23 2015 9:25pm |
philmw Member Since: 18 Aug 2006 Location: Nottingham Posts: 1672 |
Lane Departure is an option - are you sure you have it? |
Tue Feb 24 2015 6:50am |
Rainbow Member Since: 14 Jul 2014 Location: UK Posts: 67 |
Lane departure warning is listed under Driving Aids in the Manual and also under Driver Controls. There is a button on the dash near the steering column that turns it in and off. It can be controlled via the instrument panel menu also. It is speed related so comes on above 40mph. It also operates by a camera I think located in the rear view mirror which needs to be able to see lane lines. |
Tue Feb 24 2015 7:44am |
JSR2014 Member Since: 10 Feb 2015 Location: Kent Posts: 341 |
Yes, according to Topix anyway.. Thank you all for the info as well, I had no idea that menu even existed, I am excited to get back into the car now! |
Tue Feb 24 2015 8:58am |
