Home > Faults & Fixes > Range rover sport went dead 07 Hse TDIV6
Page 1 of 3 123>
samorano
hello i am new to this forum and its like my 07 RR Sport is all on-top of me My 07 range rover sport Hse TDIv6 just stopped on the way while driving then some messages started popping up on the instrument cluster that is, transmission fault limited gears available, Engine system fault, HDC fault system unavailable and system fault special program unavailable, key security light flashes, hazard light flashes, temp gauge moves to the top immediately when the ignition is switched On. we finally towed the car to a local garage and they discovered the a dumped alternator but after replacing the alternator, the car could not still start with the hazard light keep flashing, temp gauge moves to the top, key security light flashes check engine warning light just disappeared from the instrument cluster and we hv E on the gear position on the board etc. i have also replaced the battery with a brand new of same capacity, fitted a brand new engine ECU but no luck the car was sent to a more better equipped LR dealer as said so i am waiting for their feed back
Post #453568 Mon Feb 23 2015 5:54pm
Chris day
Good luck with that. I have know idear what's up with your car. Maybe something needs resetting!
I had an alternator belt and pulley fitted today and the guy did run a full diagnostics check and clear all faults before he started it up. Maybe that's all yours needs!!
Post #453572 Mon Feb 23 2015 6:18pm
samorano
yeah i hv thought of that but the local LR technician says the he cannot get access to the Transmission control and the engine control units which are all on the same CAN line he always ends with communication error
Post #453574 Mon Feb 23 2015 6:25pm
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Mines done exactly the same on Saturday with the same faults showing as yours, mines going into falcon performance on Wednesday for new alternator and battery, I think you need to get all the codes cleared aswell, mines getting collected by recovery truck.
I see on your post you said you got it towed, I don't think you can tow them.
Good luck hope it gets sorted Thumbs Up
Post #453581 Mon Feb 23 2015 7:05pm
samorano
But has urs been diagnosed already? or they just one to swap them first for test? they said they got the fault codes cleared but to no avail so
Post #453595 Mon Feb 23 2015 8:33pm
monty19
Rac checked alternator, only giving 12.5 volts, the battery was goosed and smell of eggs in the car indicated the alternator was cooking the battery and it had a small leak of acid, fingers crossed this will sort it.
The gearbox indicator was a F and only had what I believe was 2nd and 3rd, when I got it home and tried to restart it the gearbox indicator had changed to a E, I can't find any info on what these mean.
I'm having serious thoughts now of going back to BMW , I have friends who have x5s with very little issues compared to landrovers (AKA this Censored a money pit), very frustrating to say the least
Post #453604 Mon Feb 23 2015 9:30pm
samorano
ok i will be waiting for my report from the technician but does your engine management light shows on the dash when you switch On the ignition?
Post #453609 Mon Feb 23 2015 9:51pm
monty19
I've removed the battery shortly after getting home so I don't know, it was on for the 30 mile drive home, I'll fit the new one tomorrow and report back with any faults etc
Post #453611 Mon Feb 23 2015 9:59pm
samorano
ok thnk you i will be waiting
Post #453612 Mon Feb 23 2015 10:01pm
monty19
New battery fitted and all faults have cleared, I've done a HLDF test and I'm getting 13.5 volts when the engine is running and 12.5 when its off, I'll need to get a alternator check done now as I'm thinking it was only the battery that was at fault.
Post #453643 Tue Feb 24 2015 10:07am
13.5V is a bit low really. You should see over 14V. Mine runs at 14.5V when idling with the engine warm and that's with a known good, well charged, battery and an alternator that's 3 years old.
See my thread from when my alternator died:
http://www.rrsport.co.uk/forum/topic25224.html 2012 SDV6 - it's missing a couple of cylinders
Post #453645 Tue Feb 24 2015 10:24am
samorano
wow that's great pls what capacity of battery did you fitted on the vehicle?
Post #453652 Tue Feb 24 2015 11:23am
samorano
as i said my alternator and Engine control unit replaced but to no luck of which i started with a new battery
Post #453653 Tue Feb 24 2015 11:26am
monty19
Just had the alternator tested at the local garage and they have said its charging ok,
I got the battery from halfords , its a yuasa hsb019 12v 100ah 900a comes with a five year guarantee . £120 with a free tyre pressure pumpy up thing
So it would seem the RAC contractor got the diagnosis wrong
Tony
Post #453654 Tue Feb 24 2015 11:32am
13.5V suggests otherwise... 2012 SDV6 - it's missing a couple of cylinders
Post #453658 Tue Feb 24 2015 12:04pm
Page 1 of 3 123>
