Home > Maintenance & Modifications > Worried about a noise.....
Gaz
England 2007 Range Rover Sport TDV6 HSE Stornoway Grey
Guys,
Can any of you mechanical old sweats give me some advice of a potential cause?
Forgive the explanation, it's the best I can articulate.
The noise I have can be described as either a loose cowl vibrating or maybe a worn bearing in something that spins?
To narrow it down....when stationary with gear knob in Park....fine....quiet.
Foot on brake....shift to Drive.....foot still on brake, stationary.....rattling/vibrating.
I may be mad but it almost sounds louder inside than it does outside.
Have any of you guys got any thoughts?
It's been regularly serviced, driven like a baby and only has 65k on it.
Please don't tell me I will have to remortgage to fix it. Big Cry
Gaz. I was born with a photographic memory. Shame it didn't develop!
".....do you boys know what the word Nemesis means?...."
2007 2.7 TDV6 in Stornaway Grey.
EGR Blanked.
Re-mapped by Alive Tuning.
Post #453471 Mon Feb 23 2015 8:39am
simbad111
Check the exhaust heat protection shield under car mine came loose was rattling
Post #453488 Mon Feb 23 2015 11:45am
Black Bess
That would be my first thought too. A rattling heat shield above the exhaust. They are in several sections bolted to the underside of the body.
Post #453498 Mon Feb 23 2015 12:46pm
Gaz
....thanks so much guys...I'll raise her up and crawl under.
Hopefully it's that. Bow down
I wouldn't of thought the transmission or thrust bearing would need looking at when only at 65k!!! I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #453503 Mon Feb 23 2015 1:05pm
Lost for Words
Please, please, please, make sure you have your box fully flushed when you get to 75k. So many have needlessly failed by shear lack of maintenance. Thumbs Up Visiting from DISCO3.CO.UK
Post #453513 Mon Feb 23 2015 1:45pm
Gaz
Wise words.....I will deffo do that! Bow down I was born with a photographic memory. Shame it didn't develop!
EGR Blanked.
Post #453518 Mon Feb 23 2015 1:56pm
