![]() | Home > Technical > Low Fuel Warning with Full Tank |
Robbie Member Since: 12 Mar 2006 Location: Waiting for my old avatar to be allowed back... we miss her! Posts: 73 ![]() ![]() |
Probably the wiring to the level sensors in the front right wheel arch. Pretty common fault and easy to fix.
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 ![]() ![]() ![]() |
Landrover Issued a Modification for this problem. Seems it is a common fault,but they wont issue a recall,as most people with the problem go to main agents and pay to have it fixed. I have just had mine fixed,It is a fuel tank lowered and connections on the sender units changed over. They say it is a 2 hour job. So if you pay its around £300 Landrover agreed to pay for mine ![]() ![]() |
myfirstrrs Member Since: 20 Jan 2014 Location: Lancashire Posts: 433 ![]() ![]() |
Landrover paid for mine. Not the LR warranty but LR themselves. That's what the dealer told me. |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
Thanks for the replies. LRA called this morning and no fault codes associated with the problem were logged. He did a battery reset which cleared the problem for about a minute then it returned. Drove the car to the main dealer and enroute it cleared but returned again, so the car is with the Main Dealer but won't get looked at until Monday. Not a great start to RRS ownership but hopefully a quick fix. |
Yes mine started when it was under warranty, it was booked in, then it cleared so i cancelled the booking. Two months after the warranty ran out it did it again, Low fuel warning, no fuel gauge reading and dashes on miles to empty.But i knew there was plenty of fuel in tank.I drove like that for a couple of days ,and it came back to normal. I found out about the Modification from an Indie Technition, Said he heard about it at a training course. The fault code should show up in code history of uncleared codes. It did this about five times before it was fixed. By main agent,and paid for by Landrover,not under warranty itisme |
Thanks again, excellent info, makes me feel better about the outcome.
Bomber H Member Since: 17 Apr 2012 Location: Abingdon / Reading Posts: 200 ![]() |
Had the same issue on my RRS.
Thanks for that. I'm not planning to pay for the fix after only one week of ownership, that's between LR, LR Approved or the selling main dealer. I will post the result.
Car back home and fully serviceable. Job was paid for by LR. LR Approved declined to pay as it was a known fault that LR fix on a case by case basis but only if the car has a full set of service stamps. The supplying dealer, Lakeland Land Rover, was excellent and promised to sort it out if there was a problem.
Glad to hear that its fixed at landrovers expence. After mine was fixed it developed more problems, warning lights gearbox Fault,Stability Programe Unavailable Drive Carefully. Electric Handbrake Fault. It turned out to be Brake Light Switch, It seems that the brake light switch has more functions than a brake light operator. Had it Changed problem solved £24.30 for Switch £72.00 Labour £96.30 inc VAT. After argueing that the switch just plugs in and could be changed in 15minutes. They said it had to be setup. But agreed to do the job for £70.00 itisme |
The brake switch is just a humble switch and requires no setup or special installation. It is very simple to fit taking a couple of minutes.
Thats interesting Robbie. I have heard that some Merc's have problems when a rear light bulb blows. Could it be that Main Dealers put out info regarding needs to set up different simple parts,to stop small garages and private owners atempting the job? |
Or is it to be able to charge exobitant prices for a simple job? |
The pricing and feedback could be clearer, that's for sure. The D3/D4/RRS are easy vehicles to work on and there are lots of quality independents out there providing skills that outstrip main dealers at a much lower price. If you look on the D3 and D4 forum there is a wealth if community DIY knowledge that routinely turns a £1k dealer job into next to nothing or even free. Dealer's pricing tends to reflect their high cost base and diagnostics. Rather than charging a diagnostic fee and then the parts fitting price many garages charge a set fee that effectively covers their costs and profit. It would not be great business if they worked on diagnosing your vehicle for an hour only for it need a £3 part and then charge you just the £3 plus 5 mins fitting labour. I think it is preferable when garages make it clear as to what you are paying for but their is an argument that it puts-off the customer if the diagnostic time is clear and upfront. What is great in your case is that you did negotiate the price down to something more reasonable. All in all there probably was around an hour of activity on your vehicle if you add together all the minutes of manpower involved (booking in, reception, moving the vehicle twice, diagnostic hook-up, parts picking, parts fitting etc) so £70 is not a stupid price. Even though the part is cheap and easy to fit not everyone is minded to do stuff themselves, however much people like me encourage it. ![]() How To - Battery & Quiescent Current Drain Testing Free Fault Code Reading For Established Members: Defender, FL2, D3, D4, Evoque, RRS & FFRR ![]() |
