Home > Faults & Fixes > Help all sorts gone wrong
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Set of to Whitby today and the car started to smell of egg, got there ok and locked the car and the alarm went off, took awhile after closing and opening all doors and bonnet so of we went for fish and chips , came back four hours later to a flat battery, the car park attendant said the alarm had started to go off about ten minutes after we walked away, rac called sent a contractor who jump stared the car,
This was the first problem just after it was jump started, he's used a portable charger to do it
Transmission fault limited gears, drove home with what seemed like 2nd and 3rd gear
Got back to home and this thing has lit up like Blackpool pleasure beach, now we have this on the info screen.
Suspension fault vehicle lean when cornering
Hdc fault system not available
Dsc fault special program's not available
Yellow engine light fault
Turned it of and now it won't turn over at all, the battery's ok as the headlights etc come on
Can anyone shed any light on what this maybe
Tia
Tony
Post #453314 Sat Feb 21 2015 7:10pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Disconnect the battery for 10 mins and give it a go. Thumbs Up
Post #453316 Sat Feb 21 2015 7:18pm
Sounds like the battery to me. The fact that the headlights come on doesn't mean that it's good enough to run the vehicle with. Be worth giving it a decent charge with a smart charger. Once you get it running, check the voltage to see what the alternator is putting out. 2012 SDV6 - it's missing a couple of cylinders
Post #453330 Sat Feb 21 2015 7:58pm
monty19
He checked and said the battery was ok but the alternator only giving 12.5, just removed the battery and it seems to be leaking and strangely I think its bowing on both ends as if its over pressured , could this be the smell in the car maybe, I'll get anew battery tomorrow then go from there, but all advice greatly received
Post #453335 Sat Feb 21 2015 8:13pm
Bodsy
Site Sponsor
Your alternator is frying the battery. Get that swapped before you ruin the next battery. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #453343 Sat Feb 21 2015 8:51pm
monty19
Thanks for the help and info, anyone recommend a supplier for the alternator, sick as fook but that's land-rover for you
Post #453345 Sat Feb 21 2015 8:59pm
The egg smell you mentioned will be from the battery failing. It's created hydrogen sulphide gas. Nasty stuff. If you still have the battery then store it outside (or somewhere well ventilated). 2012 SDV6 - it's missing a couple of cylinders
Post #453354 Sat Feb 21 2015 10:50pm
monty19
It's been removed now, I've done a bit of digging and it could be the instument panel, I'll test it tomorrow, apparently holding in the button on the instrument panel and starting the car indicates a faulty instrument cluster, I'll report back tomorrow Thumbs Up
Post #453355 Sat Feb 21 2015 10:56pm
monty19
H2s gas,I should of realised, I work with the stuff which is bad enough but in the cars a fooking nightmare,
Post #453356 Sat Feb 21 2015 10:59pm
monty19
New battery fitted , all faults gone, alternator checked at 2 different garages, so far so good car is running fine
Post #453692 Tue Feb 24 2015 4:37pm
simon645
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Post #453716 Tue Feb 24 2015 7:00pm
