Home > Technical > Steering
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
Steering
This weeks fault!
Steering heavy. Still got power assistance- but definitely heavier than it was. Also shakes at 60. Four wheel alignment done recently.
Warranty runs out in two weeks as I'm selling it.
Any ideas please?
Post #452566 Sun Feb 15 2015 11:38am
Bodsy
Site Sponsor
Tyre pressure, lower steering column is common. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #452572 Sun Feb 15 2015 12:20pm
Disco_Mikey
Broken wire to the servotronic valve on the rack. Very common issue Thumbs Up
There will be a fault stored in the RLM if this is the issue
Post #452577 Sun Feb 15 2015 1:31pm
Bladeboy
Thank you. Will get it checked over this week.
Post #452773 Mon Feb 16 2015 11:19pm
Brooksey90
Heavy steering
Hi
I have the same fault where do I look for the valve everybody keeps talking about to check the wires ?
Post #478355 Sat Oct 31 2015 2:51pm
Disco_Mikey
Check the RLM for fault codes first.
The wiring runs down the NSF wheel arch, down the OS chassis loom to the rear of the car, over the crossmember by the EPB, back up the NS chassis rail, along the front of the car under the intercooler, then works its way up to the valve
It's a lot of wiring to check if there is no fault code stored Thumbs Up
Post #478357 Sat Oct 31 2015 3:16pm
Brooksey90
Steering
Thanks for the reply I will try get someone to plug into it and see what faults it's got is it work changing the fluid as it does look a little dark
Post #478358 Sat Oct 31 2015 3:38pm
Stu
United Kingdom 2010 Range Rover Sport TDV8 HSE Nara Bronze
I bought my RRS a few weeks ago and the guy said the steering was a bit heavy, when I went to see it but it was booked in for the bottom UJ. When I picked it up the steering wasn’t heavy but heavier than I expected especially after driving my FFRR with 20’s on.
Also had a problem with the terrain response not working, got error message on dash special programs not available. Plugged it in and no codes logged! Anyway to cut a long story short broken wire from steering column valve. Steering feels so light now and terrain response working again.. Very Happy
God I’ve missed owning a Land Rover and the fun you have... Thumbs Up Current: 2010 RRS 3.6 TDV8 HSE
Past: 2012 4.4 TDV8 Vogue
2007 3.6 TDV8 Vogue
2005 3.0 TD6 Vogue
2007 D3 Commercial
2001 D2 4.0 V8 ES
1998 D1 3.9 V8 ES
1988 3.5 V8 EFI Vogue
Others: 2007 VW Touareg 3.0 V6
1998 Jeep Grand Cherokee 4.0
1990 Mitsubishi Shogun 2.6
Post #584113 Wed Jul 17 2019 7:34pm
