Home > Faults & Fixes > Will not start! HDC FAULT, TRANSMISSION FAULT on dash |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
Make sure the car is in Park, Be sure to press the brake pedal, If that does not work it could be Glow plugs. Assuming you have a derv car itisme |
Sun Feb 15 2015 9:50am |
ed68 Member Since: 15 Feb 2015 Location: Kent Posts: 14 |
The car is in park and pressing the brake pedal makes no difference
Sun Feb 15 2015 10:01am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Only a guess but could it be a case of the notourious brake light switch strikes again 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Sun Feb 15 2015 10:03am |
That maybe the case. Just had mine changed as i had alsorts of warning lights and loss of power until took foot off accelerator,then put it back. The brake light switch has many functions on top of being a brake light switch. itisme |
Sun Feb 15 2015 10:22am |
hi, thanks for that, I've just been reading on a forum that someone had a similar problem on a Discovery with the brake light switch which was blowing fuses relating to the car starting, I will go and check all fuses now and see if I can find anything. I'm assuming the Discovery and the Sport share a lot of similar issues
Sun Feb 15 2015 10:29am |
Ok no blown fuses.
Sun Feb 15 2015 10:54am |
Replacing the brake light switch would be a low cost and easy thing to try. You mentioned had replaced the battery but did you carry out the hard reset procedure at the same time? If not then may be worth a try. Also check the battery and earth connection are clean and sound. Are your stop/tail light bulbs all working properly? Bulbs must be high quality OE. It is possible for a filament to blow and the bulb to short internally which can cause multiple problems of the type you described. Don't use cheapo Halfords bulbs.
Sun Feb 15 2015 12:11pm |
hi Paddi
Sun Feb 15 2015 1:07pm |
Search the site for hard reset. But please don't bridge the terminals or you will blow yourself up! Disconnect the battery leads and the bridge them with a jump lead or similar.
Sun Feb 15 2015 1:51pm |
thanks, I will read up about the diagnosis tool you recommend
Sun Feb 15 2015 2:49pm |
Some progress then but not really what you need
Sun Feb 15 2015 3:34pm |
hi Paddi
Sun Feb 15 2015 3:53pm |
FatJoe Member Since: 13 Dec 2014 Location: Staffordshire Posts: 259 |
Is the fuel pump belt on? What year is it and when did it have all the belts done? The fuel pump belts hardly ever get changed by garages as they are a pain to get too! Takes a few hours to fiddle about with.
Sun Feb 15 2015 7:16pm |
hi, it is 100k miles on a 2005 and can't find any history of this belt being changed, where is the fuel pump located please and I will take a look?
Sun Feb 15 2015 7:29pm |
