Home > Maintenance & Modifications > Screech from EPB
Jock 77
Scotland 2006 Range Rover Sport TDV6 HSE Java Black
Screech from EPB
Hi Lads
The other day when I used the EPB got a load screech from what appeared to be the Passengers rear wheel.also got EPB failure alarm on the dash.
Switched the car off and restarted and all alarms had cleared .The EPB appears to be working okay now but there is now a click at the passengers rear wheel just as the the brake is at final stage of applying. Any ideas what could be happening with this.
Need to use the car over the weekend and not got time to check before I go ,here's hoping all is okay. Confused
Post #452394 Fri Feb 13 2015 2:25am
monty19
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
http://www.rrsport.co.uk/forum/topic39204.html
heres my problem, weve removed the epb fuse until i get the new actuator fitted next week, hopefully yours isnt the same problem
Post #452395 Fri Feb 13 2015 7:22am
Disco_Mikey
Strip and clean, new spring kit and adjust Thumbs Up
Post #452396 Fri Feb 13 2015 7:52am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Had the same on my D3, needs exactly as Disco Mikey has said, I got it done and perfect after. Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #452401 Fri Feb 13 2015 9:35am
Bodsy
Site Sponsor
Just stop using it until you have time (or can get someone) to strip and clean/adjust.
Put some tape over the switch or as said, remove the fuse.
Brake bible link in my sig if you want to do it yourself. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #452406 Fri Feb 13 2015 10:54am
Bodsy
Site Sponsor
You're in Scotland, just get Disco_Mikey to do it, at least you'll know it's been done properly. Thumbs Up Bodsys Brake Bible
See it HERE
Post #452407 Fri Feb 13 2015 10:54am
Jock 77
Screech from EPB
Thanks for all the replies lads.
I am hoping to get a look at it on Wednesday / Thursday so hopefully it is just a clean a re-adjust as suggested by everyone.
Done Discs and pads over a year ago and the Handbrake shoes looked ok. So will investigate further .
Thanks Very much again for all the help. Smile
Post #452671 Mon Feb 16 2015 10:52am
panda
Hi guys is the spring inside the disc / drum where shoes are or is it an external?? as mine has got noisey. Had new discs, pads, shoes and actuator fitted 6 months ago. What does the spring do?? is it one that pulls the shoes together??
Thanks
PANDA
Post #452744 Mon Feb 16 2015 7:19pm
Bodsy
Site Sponsor
Panda,
Have a look through the brake bible (see the link in my sig) and you should see the Various pins and springs/clips etc in the images. Thumbs Up Bodsys Brake Bible
See it HERE
Post #452753 Mon Feb 16 2015 8:35pm
