Home > Other Site Sponsors > RRS MY10-13 Software updates from Bodsy |
Software Updates for RRS MY10-13
looks different, but you would find it under �Additional Features� section. If that is greyed out, you don�t have any additional features enabled. Timed Climate is useful all year round. For cold days, when the temperature is below 15degrees it will start the Fuel Burning Heater and will start to heat the water around the engine. It will also start the blowers inside the car. It will not make the car HOT when you get in, but it will defrost the car and pre heat the engine block. We all know that a warm engine is more efficient than a cold engine and a warm engine will wear less than a constantly cold start engine. You can set either the 7 day timer, or the single event timer. 2010 version 2012 version
For warm days, when the temperature is above 15 degrees, it will start the fans internally and help to circulate the hot air inside the car, removing that blast of hot air and helping reduce the insanely hot surfaces that you can get when leaving it in the sun. Remote Climate is the same as Timed Climate, but with the addition of a receiver, an aerial and a remote plipper. Remote Climate works best when you look out of your bedroom window on a cold frosty morning, remember that you�ve set the timer for your usual 7.30 start, but today you need to start at 6.30 and you forgot to make the change. Just press the remote button and the Climate function will come on in the same way as normal. Remote Climate Function can be added, EVEN IF YOU DON�T HAVE A SATNAV SCREEN! 4x4 Info Screen. Most RRS have this already This is a great 'gizmo', can assist in fault finding if there are any height sensor issues, but its biggest use is when in mud or parking and you�re not sure what direction the wheels are pointing. This gives you a much more accurate display of wheel direction and the heights to maintain momentum in the right direction. 2010 version 2012 version
Also gives you Compass direction, exact Lat/Long and height information, so even if the satnav is driving across fields, you at least will always know where you are. 2010 version 2012 version
Those that take it further afield or off the beaten track, then if you have an accident (or you come across a stranded walker/horse rider etc that needs emergency car, you have the right Lat/Long to give to the relevant service. But it doesn�t make you a cup of tea and it won�t peel your grapes for you (unless you have the LuxXL model) Locking Chirp Whilst you can get the mirrors to fold whilst locking the car, sometimes it�s nice to have the addition of the reassuring CHIRP or CHIRP CHIRP when locking or unlocking the car. This can be enabled Follow Me Home Reverse lights Same as the D3/RRS, this can be enabled so that when you use the third button on the key remote, the front lights come on, press it a second time and with this enabled, it will put the reverse lights on as well. This is great for when you need to unload the shopping/tools/dead bodies and you want to have more light whilst doing so. Steering wheel paddle shift enable You can retrofit the steering wheel paddle shifters for the extra sportier look. Towing Electrics You can easily fit the LR towing electrics, but they will need enabling in order to work properly (some cars they will physically work, some cars they won�t depends on the settings. But to avoid going into off road mode when you have a caravan or similar in tow, you will need them to be enabled. Should also stop the reverse sensors beeping when you have something connected. Use Horn as Alarm Sounder The standard alarm sounder on a RRS is pathetic quite frankly. I can enable the alarm to use the horn as the sounder so that you can definitely hear it. Reverse Camera Reverse camera can be enabled, so everytime you go into reverse, it will put the reverse camera screen up. But you will need of course to also actually fit a reversing camera. Either the LR bits (about �200) or one in the tailgate handle light area, anywhere from �10 to �100 for the camera + fitting depending on supplier and quality! There are other bits that can be enabled, but these generally require much more work, wiring and modules to be fitted. As I remember other little bits to enable, I�ll try to add them on here. If anyone is interested in any of these updates above Discovery 4, RRS or the Discovery 3 updates listed (Clicky Here), please let me know directly. Many thanks Bodsy (Ian) Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE Last edited by Bodsy on Thu Mar 05 2015 11:28pm. Edited 2 times in total |
Wed Feb 11 2015 11:44pm |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 |
Ian I'd like the "Chirp" and the gearbox re-set when you are down my way again please. |
Thu Feb 12 2015 3:23am |
Bodsys Brake Bible
Thu Feb 12 2015 11:27am |
fkarim Member Since: 14 Apr 2012 Location: London Posts: 2216 |
Didn't know about "follow me home reverse lights" and "horn as alarm sounder". I should have checked out new functionality after updating firmware to v3 a while back ... or may be these features were always there and I never noticed Will be making these changes to mine Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Thu Feb 12 2015 2:24pm |
Peachy, no problem. Bodsys Brake Bible
Thu Feb 12 2015 2:43pm |
Thu Feb 12 2015 2:49pm |
Weathers getting colder again.... Bodsys Brake Bible
Wed Feb 18 2015 4:32pm |
AlanEricThompson Member Since: 14 Oct 2013 Location: Nuneaton Posts: 96 |
I like the timed climate control, I already have the 4x 4 screen. Is this an upgrade that my local dealer could/ should do? 3.0 HSE RRS Stornaway (current)
Fri Feb 20 2015 9:17pm |
Andyjay123 Member Since: 22 Aug 2014 Location: London Posts: 698 |
Ian can I get to on mine? 2006 RRS Supercharged 4.2 HST muthuaflecka! |
Fri Feb 20 2015 10:08pm |
No, dealers can't change it.
Fri Feb 20 2015 10:50pm |
Willywilson1980 Member Since: 04 Oct 2015 Location: Chester Posts: 9 |
Hi bodsy - tried to PM but just signed up and won't let me. I'm interested in the software update to allow timed climate. I have a 61reg RRS 12MY (SDV6). Can you PM me with details? I'm based near Chester. Cheers, Paul |
Mon Oct 05 2015 12:00am |
Hi Paul, no problem, will drop you a message. Bodsys Brake Bible
Mon Oct 05 2015 5:30am |
Hi all - does anyone have experience on which is more useful......timed or remote climate? |
Mon Oct 05 2015 7:50am |
Depends on your driving pattern. If, for example, you leave for work and back home around the same time daily then timed could be very useful to prepare the car for you without you needing to remember. If it is more unpredictable then remote is better. Remote requires additional hardware whereas timed should just need to be enabled on your car. You can have both by the way.
Mon Oct 05 2015 8:08am |
