Home > General > SAt Nav Versions across age of RRS |
the display used changed in 2012.
Wed Feb 04 2015 4:49pm |
chatuge Member Since: 04 Feb 2015 Location: West Sussex Posts: 60 |
Is it worth the stretch? Are they chalk and cheese? |
Wed Feb 04 2015 4:59pm |
Thesurveyor Member Since: 14 Jan 2015 Location: North West Kent Posts: 8 |
I just swapped across from a 2009 FL2 into a 2012 RRS and yes the SatNav is very different and much better (mind you it is in the last Freelanders as well). Finer, more highly defined graphics if that makes sense and it dims at night (the screen was always too bright at night in the Freelander).
Wed Feb 04 2015 7:12pm |
Thanks for the tip. If you took the sat nav out the equation is the other one OK? I tend to avoid using inbuilt sat nav and use my garmin instead as its so much better. |
Thu Feb 05 2015 8:55am |
If you mean "Is the RRS OK compared to the FL2?" then the answer is a resounding "Yes". Its a vast improvement, more refined and powerful and the boot space is much much better. If you get the last of the line you get the 8 speed auto, power tailgate etc which are excellent. My first tank even returned 29mpg which is about the same as would have got out of my Freelander.
Thu Feb 05 2015 10:17am |
