Home > Technical > Newbie with dead TDV6!
Beanmasteruk
TDV6 and it wont start! cranks over fine, and quickish too, just wont fire at all....any ideas people?
My launch diagnostic shows battery vaults at 11.80 and drops to 10.60 when cranking over. Bothe EGR's mirror readings so doubt one is stuck open.....
Post #451189 Wed Feb 04 2015 9:02am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Seems like a fuel pump problem itisme
Post #451198 Wed Feb 04 2015 10:33am
Lost for Words
That battery is not sounding great. My bet would be on failing glow plugs.
Be aware that they can snap all to easily when an attempt is made to remove them. Sad
Many substitute them with a Fuel Burning Heater controller, which allows the car to be warmed up beforehand. Thumbs Up Visiting from DISCO3.CO.UK
Post #451200 Wed Feb 04 2015 10:36am
harrygh60
Remote Fuel Burn Heater will not work with a low powered battery. Normal power of a good battery is around 12.4V / 12.7V. itisme
Post #451204 Wed Feb 04 2015 11:06am
Lost for Words
The low voltage threshold for the FBH is 9.something volts.
At 11.8 volts, the battery is down to only 30-40%.
Post #451212 Wed Feb 04 2015 12:10pm
Beanmasteruk
I left it on a battery charger for about three hours and she started fine! Kinda looks like a duff battery then? I've just scared myself stupid reading up about snapped glow plugs.....oh lord i hope i don't need to change mine..... Sad
Post #451213 Wed Feb 04 2015 12:12pm
Lost for Words
Keep monitoring the battery to see if it's holding charge; highly likely it is the culprit.
Worth keeping an eye on the alternator too to check it's charging properly. Thumbs Up
If you do need a new one: http://www.tayna.co.uk/EA1000-Exide-Premiu...P7488.html
Use discount code D2BOYS. Wink
Thumbs Up Thumbs Up Visiting from DISCO3.CO.UK
Post #451216 Wed Feb 04 2015 12:19pm
hard2beat2014
United Kingdom 2005 Range Rover Sport TDV6 HSE Chawton White
if the temp was below -2 then you need new glow plugs , try a bit of easy start if it starts and then starts for the rest of the day you need new glow plugs
Post #451279 Wed Feb 04 2015 7:59pm
