Home > General > Snow Chains Question
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Firstly hello everybody, not been on for a long time, please dont ask but it did not involve anything at Her Majestys Pleasure!!
Going to the Alps from 4th April - 10th and was wondering if i will have to have snow chains with me, if yes is there anybody out there that could rent me a pair for 20" wheels.
Many thanks
Post #450213 Thu Jan 29 2015 3:14pm
fkarim
Yes, you do need to carry them by law and *might* be asked to show if weather is bad, for example, when going up a mountain. This is regardless of fitting winter tyres AFAIK.
I have the LR ones, only ever used on my driveway to practice fitting and adjusting chain size for 20" wheels. Didn't need to use them in the Alps despite heavy snow last month. Probably not practical to lend you given the location but hopefully someone more local to you will be able to help Thumbs Up Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #450219 Thu Jan 29 2015 3:50pm
Where abouts are you making the crossing? Hull or down in Kent?
If in Kent, there used to be a firm that you could pick them up from en-route and drop them off on the way back. I'll try and find the name, but I've used them a couple of times, reasonable too Thumbs Up ON THE WAY: BMW F21 M140i
Post #450221 Thu Jan 29 2015 3:57pm
fkarim
There are mail order companies that rent out chains too ... RoofBox for instance. Google "snow chain hire". Just make sure you get the ones that allow for little or zero clearance because if you go for the conventional ones and actually need to use them, you risk chains getting caught in brake or suspension components. Thule and Spikes Spider make some zero clearance chains. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Post #450224 Thu Jan 29 2015 4:06pm
leedsunited
Cheers BC, we are going on Eurotunnel
Post #450249 Thu Jan 29 2015 5:25pm
Will try and find the name of the company as wasn't far from the ET Thumbs Up
24 hour pick up/drop off too. ON THE WAY: BMW F21 M140i
Post #450254 Thu Jan 29 2015 6:32pm
nigel52
United Kingdom 2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
Why not take /buy snow socks they are circa £50 to buy and are accepted by the French police as substitutes for Snow chains. They are much easier to put on and take off. The Roofbox company sells them as well. Make sure you get the approved ones and not a copy.
Post #450317 Fri Jan 30 2015 12:26am
nigel52
Post #450318 Fri Jan 30 2015 12:26am
JB72
Sweden
With proper winter tyres most countries do not require you to carry snow chains in the car, however Germany, Switzerland and Austria requires that you have proper winter tyres on Winter roads - snow chains or no snow chains.
You might however not be allowed to travel up a road without chains mounted on the wheels if the conditions are extreme, but then again in April you would be very hard pressed to find any snow covered roads in the Alps at all. 2015 Range Rover Sport HSE TDV6, Corris Grey
Post #450320 Fri Jan 30 2015 1:07am
leedsunited
Thanks guys, think i will purchase Snow Socks then i have them for next year as i doubt i will need them in April this year< he hopes !!!! Wink
Post #450343 Fri Jan 30 2015 2:00pm
myfirstrrs
leedsunited,
You might want to first check that snow socks are legal to use in the countries that you will be driving in. Both the AA and RAC websites, and probably many others, show what you need for which country. It doesn't seem to be a black and white list as there are some slight differences between the websites but it gives you a good idea. Implementation of the rules will also be weather dependent.
Post #450349 Fri Jan 30 2015 3:06pm
